swapping out carbs
  • rizzo4u2
    • Nov 2007
    • 49
    • hanover,pa.
    gas in airbox
    thankyou for the info i will try both of theses ,drop the carbs again pull the bowls, and check the seats on thesefloats , now for the petcocks your saying no fuel should come out in the run position or the reserve position or the prime until a vacum is drawn correct last year no problem, after market kit was installed, also had problems with no. 3 and4 air mixture screws tips braking off, got those out
    with the tips that were given, thankyou
    mike.s
    • foreda
      • 949
      • Southwest Louisiana
      Petcock
      The only time fuel should come out of the petcock is when the handle is in the "Prime" posistion. These petcocks do not need vacuum in the "Prime posistion for fuel to flow. Like everyone else said in this post, if you are getting fuel in the airbox, you have 2 problems. The petcocks are leaking and you also have leaking float valve. Make sure you change the oil before running it with gas in the lube oil!!
      78 XS1100E Standard
      Coca Cola Red
      Hooker Headers
      http://i408.photobucket.com/albums/p...m/DSC00580.jpg
      1979 XS1100 Special
      http://i408.photobucket.com/albums/p...m/DSC00612.jpg
      1980 XS Standard
      http://i408.photobucket.com/albums/p...m/DSC01137.jpg
      2006 Roadstar Warrior
      http://i408.photobucket.com/albums/p...um/warrior.jpg
      • rizzo4u2
        • Nov 2007
        • 49
        • hanover,pa.
        i will check th e petcocks no.1then check all the float seals ,no.2 thenchange the oil after all this ill get back to you in a couple days to let you no the results , thanks again
        mike.s
          Hey Rizzo,
          It may be too late, you're probably already out in the garage tinkering, but the upper "T" vent tubes are actually quite CRITICAL that they are clear and venting....otherwise, they WILL cause the carbs to flood even with good float valves.
          Folks have found that the ports that they had the hoses plugged into in the AIR BOX were clogged, and so they weren't venting!
          Be sure to check the vent hoses, that you can BLOW air thru the "T"s into the carbs thru the hoses....the can get clogged in the "T"s as well, and then check the Airbox ports....or if you're using Pods, then be sure the hoses are connected to a venting "T" fitting tucked up under the tank, so that AIR can get into the hoses and provide the proper balancing pressure for the float bowls!! JAT!!
          PS, doing a search for alternate carbs or such should reveal a few threads with info about other carbs from other years/models that folks have been able to make fit with minor mods...IIRC it was the FJ carbs...newer parts still available, etc., but also GXSR as well!?
          • rizzo4u2
            • Nov 2007
            • 49
            • hanover,pa.
            problems as usual
            well i checked the carbs again, dropped the bowls and found one looked a little heavy ,pulled it it had fuel in it replaced it with another i had, all others are fine , blew everything out also the t fiitings everything is good, mounted back up, pulled the plugs to clean again , now i have another problem ,noticed that the no, 2 plug did not seat well, the plug whole is stripped out, okay pull the head or heliocore it what do you think
            mike.s
              IMO, you do both. I would add the helicoil kit, but I would pull the head to do it. Last thing I would want is the metal drill filings from installing the helicoil in my cylinder.
              • dpotter58
                • Aug 2004
                • 1846
                • Southern Maryland
                Try a thread chaser first...
                1980 LG
                1981 LH
                • randy
                  • Dec 2003
                  • 4521
                  +1 on the thread chaser. A bit of oil on the chaser will pick up any small chips. Do a few turns, a little at a time. Each time go a few turns deeper. Clean off and re-oil the chaser between runs. I've saved many a plug hole that way.
                  • Ivan
                    • Jul 2008
                    • 2524
                    • Hutchinson KS
                    Good luck finding a thread chaser. I tried to find one here, but they were only for the standard automotive threads, so motorcycle stuff is out.
                    Good news is that Snapon will ship you one, I think mine was less than $5 shipped.
                    Ich habe dich nicht gefragt.
                    • randy
                      • Dec 2003
                      • 4521
                      Lisle makes 'em, 14mm one end, 18mm the other end. Most of the shops up this way carry Lisle tools.
