Dmm
  • MNS494
    • Jan 2010
    • 32
    • BOISE, ID
    Dmm
    Some where in this site is a list of what all the abbreviations stand for.......but i can't find it again.....help?
    DENNIS
    1981 MNS..1980 CARBS , STOCK AIR BOX, FIVE 1/2" HOLES IN BACK OF MUFFLERS (SINCE COVERED UP WITH A BIG WASHER)
    1983 HONDA 350R
    1972 YAMAHA 250 MX
    196? MONTESA 250 ENDURO STRIPPED DOWN
    1967 BENEILI 125 ENDURO (NOWHERE NEAR BIG ENOUGH)
  • MNS494
    • Jan 2010
    • 32
    • BOISE, ID
    Dmm
    Found the page but it didn't tell me what dmm stands for.......
    DENNIS
    1983 HONDA 350R
    1972 YAMAHA 250 MX
    • XSokieSPECIAL
      • Jun 2009
      • 1631
      • Tulsa, OK
      Don't see that one.
      • randy
        • Dec 2003
        • 4521
        Digital
        Multi
        Meter
        Unless you do board-level electronics work, you don't want one anyway. But then, if you did, you might know the acronym If you do shop for a multimeter for use on the XS, get an analog one.
        Excuse me now while I duck to avoid the flack. This subject can be a controversial one
        • Rasputin
          • 3193
          • Lacombe, Alberta, Canada
          Dmm stands for digital multi meter. The page with the acronyms is here http://www.xs11.com/forum/showthread.php?t=1011
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
            Originally posted by randy
            Digital Multi Meter.
            Hi Randy,
            the readout style is irrelevant, what's important is the scale range.
            What the average electro-ignoramus needs is a meter that has settings that include those that read 0-20VDC and 0-10 Ohms and don't cost much.
            A meter that reads 0-10V, then 0-50V and has a single 5,000 Ohm scale is neither use nor ornament for checking bike stuff.
            • randy
              • Dec 2003
              • 4521
              Fred, of course you're right, BUT. The point I try to make here as I have in the past is that the guys who ask questions like that one don't own one, and more than likely don't know how to use a multi-meter, regardless of readout type.
              Often I see well-intentioned members advise newcomers to get the best meter they can find I just think it's a waste of cash and a digital can confuse the new user. Ever see a digital do the devil's dance while testing continuity through 30-yr old corroded connectors? Useless. A good old test-light would do a better job. DMM's are great for semiconductor work or for work on the latest automotive systems, but if you've never even used a meter before, are you really going to dive into work like that? Good luck.
              So my advice (for newcomers) is go ahead and get a $10 harbor freight or dollar store analog meter. Learn what those ranges mean and how to interpret them. Then when you're ready, splurge on the $100 Fluke DMM and go nuts. But if you have to pick ONE that you wouldn't mind accidentaly running over in the driveway, well, I think I've made my point.
              • CatatonicBug
                • 6117
                • Clinton, UT
                I agree. I own both an analog meter (non-powered, for voltage only) and a super-cheap digital one. I use both of them, total, about once a year. This last weekend was the first time I have EVER measured Ohms. I realized that my meter does not measure Ohms at a low enough level (starts at 2k) to work for everything, but it works well enough. If I used it more often, I might think about getting a nicer one, but my cheapo versions have served me well for the last 20 years.
                • xs11jack
                  HALF GURU
                  • Nov 2002
                  • 606
                  • O'Fallon, Mo.
                  Walmart sells one
                  a digital meter with a temp probe for 17 bucks. Bought one(that makes five defferent ones spaning 40 yrs.) just for the temp probe to check temps on the headers. it's handy.
                  J.D."Jack" Smith
                  1980G&S "Halfbreed"
                  1978E straight job
                  "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
                  Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
                  • randy
                    • Dec 2003
                    • 4521
                    Cool. Jack, where did you get it? Online?
                      Yeah, I would love it for the temp probe. I have a decent DMM, but temp is the one thing I don't have (other than the cooking temp device and it's a little hard to use on the bike.
