I would like someone to fill thier bathroom sink with a couple of inches of water and then pull the plug and see which way the water spirals down the drain. Clockwise or counterclockwise. And then tell me.
I need help from our Bro's downunder.
J.D."Jack" Smith
1980G&S "Halfbreed"
1978E straight job
"We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.Tags: None -
XSokieSpecial,
As sooon as I set down my glass of Grog, I win asher to that, what ever you said.J.D."Jack" Smith
1980G&S "Halfbreed"
1978E straight job
Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.Comment
Coriolis effect
The water will drain clockwise, north of the equator and counterclockwise south of the equator due to the Coriolis Effect. On the Equator the water will drain either way. If the Earth was to stop rotation there would be no Coriolis Effect. The major currents in the Oceans will follow the same directional rotations also due to this rotationally induced effect. We need someone from down under the Equator to respond there results ........Mike in Sun Diegomike
1982 xj1100 maxim
1981 venture bagger
1999 Kawi Nomad 1500 greenie
1959 wifeComment
Clockwise.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
Dang it Brian, I had food in my mouth when I read that quote!! Struck me as very funny, and now I gotta clean up my keyboard!Life is what happens while your planning everything else!
78 XS750Comment
Bathroom goes clockwise, kitchen sink goes counter clock ?? must have something to do with sink design.1980 SG. (Sold - waiting on replacement)
You know, IIRC many toilets are designed to actually force the water to swirl. That would entail a specific direction, since the swirl is done to help cleaning of the bowl when you flush. Most sinks just swirl the way the water wants to go rather than pushing it in a specific direction.Cy
You know, IIRC many toilets are designed to actually force the water to swirl. That would entail a specific direction, since the swirl is done to help cleaning of the bowl when you flush. Most sinks just swirl the way the water wants to go rather than pushing it in a specific direction.Comment
"The Flying Pumpkin"Comment
I'm thinkin' there must be a bet involved...lolGuy
'78E
Quidquid latine dictum sit, altum videturComment
