Ok, I guess I do need rain pants
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    I left for work this morning, and since it was just barely sprinkling, and I go a short distance I figured I was fine. Well, yeah, mostly. Seems these things throw up a lot of water off the front tire, and that does have the unfortunate effect of making the lower leg waterlogged. And I found that having a hole in the bottom of the ignition cover is NOT a good thing.
    So this weekend I'm going to take it off, clean it up and use JB-Weld and an aluminum can to patch the hole (I'll replace the cover later) so that it's at least waterproof.
  • Montreux_Blue
    XS-XJ Guru (Deceased)
    • 1143
    Famous Myspace quote:
      • 7821
      Cycle gear up near Roseville (you can see it off 80, next to the old jet that was on a pole), IIRC, has a good selection of rain gear. I use the two part pants/jacket system. I paid about $45 for them three years ago! Just the pants will keep you dry in most storms. Add the jacket and some overboots and you can ride all day and stay dry!
      • Athedra
        • Oct 2009
        • 221
        • Benoni, South Africa
        Think you just had a bad rain day.
        I use Bones daily, and dont worry about the weather. I have a leather padded bikers jacket and my colour (Also leather with all my patches and badges on) over that. In rainy weather, only the top of my legs get wet, and in bad weather, my ass and the whole front of my pants.
        I must add that when it rains in South Africa it doesn't play, and bikes normally slow down to about 100km per hour when the rain hits.
        If you wrote you need wiper blades for your helmet, I would have agreed with you, but rain suite pants...... not on the top of my list.
        '79 XS1100 (2H9) named Bones
        1196 Big Bore
        4-1 Cowley exhaust
        750FD Conversion
        Echlin 54mm Racing Cones (Americanese = pods)
        Black Ebony Bottled glazed Tank (To be redone now)
        BMX footpegs
        Tank internally lined (Professionally this time)
        GSX400 Throttle bodies (Under serious investigation)
        Anti Sticky float bowl system
          • 7821
          You need to remember the rain here is at about 5C to 10C, not 20C. You DO get COLD in the rain here!!
          • XSokieSPECIAL
            • Jun 2009
            • 1631
            • Tulsa, OK
            Interesting.................this doesn't bother you?................ is this something you would NORMALLY see in South Africa?
            Hmmmmm....... How does that make you feel?
              Wow Greg... Sounds like you have some experience on a shrink's couch! lol.
              Agreed though.. don't want a wet front OR "back".. but the WORST for me is wet feet! Seems like most of the things I've tried, even though they say "rainproof", it usually means rain resistant is all. I haven't found many things that can take 70mph wind driven rain for very long, including gloves, boots, or coats.
              I have been through several sets of rain pants, and the ones I found that work well for quite a while are at Bass Pro Shops. I'm thinking the brand is RedHead. Bob Falter told me about him and they worked well for him also. They say they're fishing pants... just that nylon type material, but they come in a little carrying pouch a little bigger than a hot dog and are $20. Most other stuff tore up after a good long ride, and these lasted a season before they started to finally leak. They also have snaps at the bottom to keep them secure around your boots. Since I ride with a fairing, I mainly get hit from the knees down. Without the pants or covers of some sort, the rain soaks my pants and runs down into my boots. Remember that part I said about wet feet? lol.
              • XSokieSPECIAL
                • Jun 2009
                • 1631
                • Tulsa, OK
                heh heh...... no but I've been around a lot of crazy people.
                Of course I don't mean that towards you Athedra.
