What year did the standards go tubeless
  • DenyP
    • 599
    • Staples, Minnesota 56479
    I am thinking about getting a set of tubeless wheels for my '78 1100. With the rim locks, I flat repair on the roadside is next to impossible. Anyone know what year yamaha went to tubeless rims on the 1100 standards?
    Deny
  • GARTHXS
    • 1631
    • Seattle
    79?
    My f was made 1/79 and it has tubless rims
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • randy
      • Dec 2003
      • 4521
      Yes mid 79 they changed. My 79F was tubes and I changed to tubeless rims easy direct swap
      • DenyP
        • 599
        Thanks!
        Deny
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          For sure an 80 will be tubeless.
            Deny
            Hi Deny,
            I have gotten away with putting tubeless tires on XS series cast wheels that did not have the "for use with tubeless tires" legend stamped on them.
            The rim configuration did not change but if you are worried about air leaking through casting porosities, give the tire well a few coats of epoxy paint.
            • 79XS11F
              • 3563
              • Ottawa, Ont. Canada
              The tubeless tires started showing up in Canada on late production 1978 models. It appears to have been a split across that year. My original 1978 model came off the showroom floor with tubeless tire rims.
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • DenyP
                • 599
                Hi Deny,
                Fred,
                How did you deal with the bead locks?
                Deny
                  Denny,
                  Some people have put stove bolts in the holes, others have used other methods to seal them up. I would tap the hole, screw in a set screw with sealant on the threads and call it done. You could put some sealant over the screw from the inside of the rim, just as a second seal.
                    Fred,
                    Deny
                    Hi Deny,
                    as I remember, it was a front and didn't have them.
                    For a rear, what Diver Ray said.
                    • DenyP
                      • 599
                      Denny,
                      Thanks Again! Never thought of it from that angle.
                      Deny
