Finally
I got it all together and running. Turned out that because I didn't put a spring and bolt on the the clutch pack while I was putting it in the pack shifted a little and the bottom steel was out of align so the pack didn't go all the way together. Took it apart and did it right and now everything is good. I figure I'll have to adjust the clutch a few times in the first couple hundred miles, and I plan on changing the oil after no more than 500 miles, but the new motor is running strong and quiet. It felt good to take it around the block and then down to the gas station to fill it up.
Now, I gotta to over to my folks house tomorrow and put their nieghbors timing light on it and get it timed right, and then when I finally get paid (employer didn't make payroll, so I have a job but no money (well maybe I still have a job, depends on how long it take them to make payroll)), I can order the carb sticks I found on ebay and do a proper sync (rather than the bench sync I did).
But, so far I'm quite happy, even with the fact that all my problem with the clutch were my fault (just like I thought all along). Remember to make sure that pack stays together when putting it in, it's really easy to get it out of align while inserting it (at least is was for me).
Thanks to everybody for all the suggestions and support on this project, you guy rock!!
(does take a little longer tho)
(Sold back to Maximan)
