Better Handling anyone tried this?
  • Elevener
    • 608
    • small town in TEXAS
    intro
    company
    product
    Looks interesting with a solid background.
    Trapped in time. Surrounded by evil. Low on gas.
    1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
  • petejw
    • 2269
    • sydney australia
    Hi Elevener,
    I know of 2 who have them fitted to the xs and are
    really happy with the emulators once theyve been set up
    correctly. Unfortunately they dont come on here anymore,
    they do visit the uk site so you might be able to get some more
    info there, if you cant get any more from here.
    Are you heading out to the expo? looks like you could get some good info from there.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • aussixs11G
      • 76
      • Brisbane Australia
      RaceTec emulators
      got em - love em
      have a look back thru my posts here for details and rave....
      Bryan
      Bryan H
      "Conan, what's best in life?"
      "To crush your enemies, drive them before you and the lamentation of their women"
      • Elevener
        • 608
        petejw,
        I sure have plans to. I guess I will know by tomorrow.
        I havent recieved my commision check yet though and just bought a motorcycle trailer I couldnt pass up. So now its a funds thing.
          Great product, although a bit expensive IMO. I've ran these on other bikes with very good results. Their main claim to fame is the complete ajustability, as you can tune them to your weight and riding style. But they are a real PITA to adjust if you're trying to get every last bit out of them, as you have to remove them to adjust. So it's pull the fork caps, springs (getting oil everywhere), fish them out with a long wire, adjust, then reverse to install.
          They do come with very comprehensive instructions and they'll give you a pretty good 'baseline' setup, so you may not feel the need to fine tune them. I would not recommend the RaceTech springs however, as they only sell 'straight rate' springs and these can be harsh in 'normal' riding. The Progressive springs work well with these. I did find that if using the Progressive springs, using RaceTech's spring pre-load instructions for the spacers gave the best results.
          '78E original owner
          • yamahansolo
            • Aug 2007
            • 1113
            • jawga
            hey i am looking to d othis as well... i have also read they work well with progressive springs... also i tohught you still need to use the 10w oil... when you enter the info for the xs11 on the racetech site they show you using 20w oil...???
            79 xs11 standard
            8mm msd wires
            tkat fork brace...
            Fox shocks...
            mikes650 front fender
            led's gallore...
            renthal bars
            gold valve emulators
            vmax tensioner
            Rifle fairing
              How good can you actually make an old set of forks? Sure, you can get the up and down adjusted, but the problem with these old forks is the flex sideways. A fork brace HELPS, but doesn't cure the problem completely.
              It just seems to me that the better fix would be better forks off of a newer bike?
              • Mathh
                • Nov 2006
                • 698
                • Beek, Netherlands
                Try these:
                click
                I have been told these are exact replica's from the racetech but far cheaper.
                If you're not in a hurry... In a couple of weeks I will install these in my fzr1000 rsu forks for my racer project
                MV Agusta Brutale 910R '06.
                Yamaha MT-09 Tracer '15 grey.
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  If I am understanding this correctly, these cartridge emulators are merely spring loaded check valves in which you adjust the amount of pressure it takes to open the check, so the suspension acts normal until it hits a hard jounce, in which case the check opens and lets the oil bypass the dampening orifice allowing the suspension to absorb hard jounce but remain firm under normal riding.
                  Sound about right?
                  Ich habe dich nicht gefragt.
                    Sound about right?
                    That's pretty much it. The RaceTech's do allow you to adjust both compression and rebound damping semi-independently by changing springs, etc.
                    '78E original owner
                    • melbxs
                      • Jul 2008
                      • 58
                      Originally posted by Mathh
                      Try these:
                      click
                      Mathh
                      From what I can see they are the same price as the Race Tech ones. Over-priced.
                      MikesXS has a copy set for XS650's for $50. Wish Mike would supply for the 1100's.
                      Melbourne, Australia. XS1100RH
