Yamaha sports fairing
  • petejw
    • 2269
    • sydney australia
    Im trying to figure out how it attaches and fit
    and for the life of me cant figure it out,
    heres a cpl of pics.
    thanx in advance
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • Silent
    • 343
    • San Jose, CA
    To me, it looks like the mount uses the factory turn signal location to hold the frame. Probably uses a relocation bracket (that I dont see there) for the front turn signals also. It also looks like it uses 2 windshield bolts for the top, and something I can't quite make out for the bottom. 4 point on the fairing, 2 points on the bike.
    My guess anyway
    Ray
    '07 FJR1300
      Not sure...........but if its mounted to that table, someone is gonna be unhappy.
        • 7765
        I just hope the iron in the background ISN'T ready to "clean" the windshield in the photo!!!
        • Shappers
          • Sep 2006
          • 158
          • Helsinki, Finland
          Hi Pete,
          It attaches like this..
          Basically it attaches to the same two screws on the front of the bottom yoke that the Sport indicators bolt to.
          '84 Sport
          • petejw
            • 2269
            • sydney australia
            Hey Shapps,
            Thanx for the pic and reply,
            but i still cant figure out how it attaches,
            nothing lines up, not sure if im missing any pieces or not.
            The indicaters on mine are attached to the side of the bottom yoke,
            this bracket doesnt come close to that.
            Need a pic to see how its mounted, any1 got 1?
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • ozlad
              • 42
              • Mackay,Queensland,Australia
              I will take mine off tomorrow an photograph for you took me a while to figure out how to get it off
              '81 XS1100R
              4-2-1 exhaust Tranzac (Current)
              Everything else stock (as far as I know)
              Previous:
              Honda scrambler horse( had to start somewhere)
              Yamaha DT175
              Yamaha XT250
              Yamaha TT500
              Suzuki DR250
              Yamaha XVS1100
              Honda 750/4 K (basket case, current)
              • Steptoe
                • 175
                • Thabeban,Bundaberg QLD , Australia
                mounting
                1, the frame in the diagram needs to spin around.
                2, the bottom holes pick up the bolts beside front blinker mounts on the bottom of triple tree
                3, the 'ears' will pick up the headlight pivot bolts & the two small ears on top of the frame hold the fairing at the base of the screen
                4, there is also a small mount at the base of the fairing itself that a small home made bracket also attached to the bolts at the bottom mount bolts will stabilise the whole show hope this helps, -----PS---- make sure you don't tighten the screen bolts down far, cause it will crack before you know it
                never ride faster than your gaurdian angel
                can fly
                1981 rh 5N5
                MIDNIGHTSPECIAL
                1188cc
                4 into 1 pipes with a transac muffler,
                as the motorcycling gods intended everything else stock std
                http://s856.photobucket.com/home/steptoexs11
                http://steptoexs11.webs.com/
                http://www.youtube.com/my_videos?feature=mhum
                1982 vf750 sabre
                • ozlad
                  • 42
                  Mount photo's
                  Hope these help
                  Top
                  '81 XS1100R
                  Previous:
                  Yamaha DT175
                  Yamaha XT250
                  Yamaha TT500
                  Suzuki DR250
                  Yamaha XVS1100
                  • ozlad
                    • 42
                    '81 XS1100R
                    Previous:
                    Yamaha DT175
                    Yamaha XT250
                    Yamaha TT500
                    Suzuki DR250
                    Yamaha XVS1100
                    • petejw
                      • 2269
                      • sydney australia
                      Pics were great, thanx again Ozlad,
                      Thanx for all the replys, got it all fitted up.
                      I had a chrome cover covering the front of the bottom yoke,
                      so had to pull the forks out to get it fitted.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
