Cam chain adjustment
  • Rocknroll90
    • Aug 2009
    • 48
    • Kearney, ne
    I looked at the owners manual and it says occasionaly this must be tightened. Give me an idea, since I just got this bike should i tighten it. I believe I hear a chainish sound at higher RPM'S.
    Thanks
    There is a VERY fine line between "hobby" and "mental Illness"
    I don't own a classic I RIDE one
    Brad Norton
    Kearney, Ne
    Photojournalist
    Hobbies-Family
    rock and tree climbing, rescue ropes, firefighter, Boy Scouts leader, metal detecting and camping
    age 49
    1980 XS1100SG Special- My very first bike!!!
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    Take off the timing cover (left side)and turn the engine clockwise to the "C" mark . Maybe a full revolution first .Loosen the lock nut and back out the bolt on the front of the engine . The big spring inside should do the adjusting for you . Lightly tighten the bolt and the locknut . Did I forget anything ?
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • XJOK2PLAY
      • 2099
      • Skiatook, Ok.
      Axel covered it pretty well...
      But, if I may add a word of caution... search a few recent threads here about this before you do it. Most times, it works fine & is necessary.
      But...Sometimes it can be disasterous...
      Read the thread... "Got defeated this weekend" by Trbig...
      The owner, and fellow member, Bohn Frazer is VERY knowledgable, and this wasn't his first rodeo by any means. Followed it to the letter... only to wind up w/ bent intake valves because the tensioner failed to work correctly.
      Trbig knows these bikes inside & out... literally.
      Just use your best judgement and a whole lot of caution.
      Regards,
      Bob
      2011 Kaw Concours 14 ABS
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        Most of the time, the cam chain will be loudest at idle, if it needs adjustment.
        Be careful on the bolt and lock nut, they strip very easily.
        Ich habe dich nicht gefragt.
