Hey there, new to forum/bike
  • #16
    I may need a new front brake master cylinder anyway.
    Do you mean I can put a 140/16 CAR tire on the rear? darkside huh, cool
    • #17
      I obviously don't know about tire sises..
      • #18
        You definitely DON'T want to use a CAR tire on a bike! Bikes have to lean, so the tires have to be rounded. Car tires are flat on the contact surface. I don't know anything about sizes, as I always just use the stock size, but there are a few options when it comes to using a wider motorcycle tire on the stock wheels. A few searches here will give you plenty to read about that topic.
        • #19
          its called darkside you could read in to it more, SOME people use a car tire on their motorcycle, but anyway..
          My rear tire has got to be at least 7 years old if not more, but it looks great, may be able to keep. Its my front that is flat that I will be replacing.
          • #20
            The wood bleach is good, but can I use it effectively just wiping--or do I have to completely remove the forks and soak the top ends in a bath for hours to achieve good results?
            • #21
              Any tire that old is almost for sure hardened and not providing good traction anymore. This is in addition to any deterioration of the casing of the tire that might cause failure.
              • #22
                Hi TajMan,
                Get New Tires. I would also suggest you get it running well with the existing exhaust to give yourself a base line for future exhaust / jetting mods.
                Maxim Phil
                • #23
                  Yeah I'll keep that kerker 4-1, It just needs sandblasted and coated with something.
                  That spare seat/sissy bar I have worth anything?
                  I was just gonna give the seat to someone for $20
                  • #24
                    Just wanted to let you guys know, wood bleach is awesome for rust removal on chrome parts.
                    I have some pieces that were completely orange, now looking brand new shiny again.
                    I think I need some 1 3/4" sections of pipe with 45 degree elbows, to fix my dented in areas that are bad on exhaust.
