Carb cleaning video I found interesting. Does anyone see anything he is doing that you like or dislike?
You Tube Carb cleaning
It looks like he will be cleaning them a couple more times. That was some half-assed work. He never addressed the pilot jet, screw or system. He never cleaned the choke circuit. He didn't remove the float and float needle. He didn't check/set the float height, nor did he even clean the bottom of the bowl. He shoudn't have used that steel pick to probe the orifice that feeds the choke circuit, he should have used a thin strand of copper, or other soft metal, wire to poke into those holes.
I hope the guy in the video isn't a member, and if he is, sorry dude, but you need to be more thorough when you clean these carbs. -
His YouTube Username is Crabblike, and would probably use the same one for here, and there's no member with that name on here....thankfully!
I didn't watch all of the clips, but like John said, not the best techniques!
T.C.T. C. Gresham
I gotta agree with John. That is the quick and dirty side of the road carb cleaning if you ask me.
Never removed the pilot jet or pilot air jet which is the most common circuit to cause trouble. Did not remove and clean or replace the float valve and seat, the most common area to cause trouble and or fires from leaking float seats. All of the removed parts should have been soaked in cleaner, he barely cleaned that emulsion tube which was dirty as crap to my eyes. Not to mention the bowl bottom. Like John said, if that is a member, do not take offense, just my opinion.Life is what happens while your planning everything else!
78 XS750Comment
The diaphrams will shrink if left out in the heat over a couple days.
I heard him say he already had the carbs apart. With how he held the carbs up removing the screws, I'd be a bit leary of stipping one or one coming out and running across the floor to hide. Same thing with the jet and washer.
You'd think he'd remove the float valve/seat and clean it if not replace them. I'm sure his float heights were affected after all that cleaning with the airgun.
Ahh well, practice makes perfect! He'll have them apart again to clean that pilot circuit. I bet he gets good and R&R the carbs any way.
RichardComment
Ya know, over the years of motorcycle ownership, Wildkat has become very proficiant with cleaning/setting up carbs. She only has to clean them once, because she knows what circuits to clean, how to clean them, and how to check that they are truly clean.
She could show this guy a thing or ten!
The way the carbs were spaced on the mounting rack makes me think they are from an XS 650? Is that the case?Comment
I also was not that impressed. His work space was a mess for a carb cleaning job nd as pointed out by others he really didn't clean them. As for carb diaphragms shrinking, Yes they will if you just leave them sitting on the bench. I have however, reused them as much as a year later but they were stored in zip lock bags after being cleaning with rubber renewer. They were only slightly smaller then original and fit easy enough.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
The way the carbs were spaced on the mounting rack makes me think they are from an XS 650? Is that the case?Trying not to offend since Aug 28, 2010
Disclaimer: I am an idiot. Pay no attention to the man behind the curtain.
Owner of:
1979 XS1100F (The Pig)
140 mains
45 pilot jets
Floats at 24mm
Running Rich
"Arrogant, delusional tyrants can't be stopped by earnest words and furrowed brows. Action, strong bold action coming from a position of strength and determination, is the only effective deterrent." -Mitt RomneyComment
I know this, because Tyler knows this.
1980 SG
3J6 003509
Kerker 4-1 (sans baffles)
Fuse Block Upgrade
Mike's XS Green Coils
Pods w/Homemade Velocity StacksComment
