1994 Honda accord high idle when in park
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    Hi again guys! Last year i had to replace my break master cylinder. Now it is showing one of the same symptoms. Breaking is still good, but it will idle from 1.5k in gear,it will jump to 2.5k if i put it in park. When i step on the breaks while it is in park the idle will climb a few hundred rpms and go back down slowly once i release the break pedal. What the hell is going on with my car??
    1994 honda accord with around 193k miles on it.
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
    • 8930
    Sounds like it might be a vac. leak. There's a hose that goes from intake vac. to your power brake booster. Check that line for leaks first. It could also be the one way check valve or the booster itself. Could also try resetting the computer by disconnecting the battery for a minute or two. HTH
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Sounds like a possible leaking boost unit.
      • Korr
        • Jul 2008
        • 293
        • Torrance, CA
        Thanks guys i will ask the family mechanic to look at it!
        Tkat Fork Brace
        On Hold
