850 perfomance cams
  • cueball
    • Jun 2003
    • 375
    • Nth Albury NSW Australia 2640
    850 perfomance cams
    Am looking for aftermarket cams for 850 project bike, used to be able to find link from XS11.com to site that listed 1100/850 cams. Can someone please advise of web adress or other site that can provide street cams?
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Check here:
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • tw1980
      • Apr 2009
      • 662
      • Bend OR
      I have megacycle cams.I can highly recommend them. Terry
      1980 special (Phyllis)
      • cueball
        • Jun 2003
        • 375
        850 cAMS
        Thanks for lead, however Megacycle only list 750, not 850.
          • 7765
          Cams for the 750/850 SHOULD be the same! It's sort of like the part number difference between a '78 and '81 cam on the XS1100. They WILL both work, they just have a different part number because of the "grind".
          • cueball
            • Jun 2003
            • 375
            Cams
            Looked up the sizes of the journals in my Haynes manual that covers 750/850, acording to it the 850 journals are 20 thou larger in diameter. Bugger
            • DJinNH
              • Mar 2008
              • 854
              • New Hampshire
              OK....novice mechanic question here. What makes one type of cam better than another. You are talking about the shaft, correct? Does it have to do with a more precise fit or maybe a higher quality steel? Just curious.
              Last summer I had the enjoyment of replacing the head gasket myself and had the head all apart. Man, that was fun.
              Don
              currently own;
              1980 Yamaha XS1100 SG
              2009 Yamaha Star Raider
                • 7765
                Send an email to them! it may be they want your old cams for a "core" anyway. If you don't ask, you'll never know if they will fit, or if they just don't "list" ALL the cams they do.
                The difference is in the profile, or curve of the cam lobe. They are engineered to meet "smog" requirements buy Yamaha, but aftermarket cams have a little different height and duration to increase power at a certain RPM.
                • DJinNH
                  • Mar 2008
                  • 854
                  • New Hampshire
                  Thank you for answering and giving me a little education.
                  Don
                  currently own;
                  • cueball
                    • Jun 2003
                    • 375
                    Cams
                    Thanks for suggestions, however if necessary to get stock cams reground, will get them done by company in Queensland who have excellent reputation. Between exchange rate at present and shipping two ways not worth sending o/s to get done. Had hoped that someone would have items in stock to save time and effort. Lazy eh
                      • 7765
                      Yeah, we ALL try the easy way first! Good luck with them.
                      • gene
                        • Mar 2009
                        • 267
                        • Weston, Fla.
                        I sent my cams to APE. They are big on performance and some pretty nice guys. I have been dealing with Jeff. I will have to keep you posted.
                        Gene
                        Gene (Florida)
                        1980 XS1100SG
                        Accel Coils
                        4-1 Jardine Exhaust
