Carbs can I use other ones??
  • Peter
    • 68
    • Hamilton/Ontario
    What other carbs can I use from Yamaha or other manufactures to fit on my 81 MS 1100?? I also am in the market for some emulsion tubes.
    Tks
    Peter
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    MS?
    If you mean XS 1100, you can use any year carbs from 78-81, for sure, and I think you could use 82-85 XJ 1100 carbs too.
    Just make sure you get all 4 of the same series.
    Mikes XS sells BS34 carbs that are the same as ours, but they only use 2, so I assume they have carbs 1 and 4, or 1 and 2. Takes a bit of doing but they will will work.
    There are many other makes of carbs that can be modified to fit, youcan use the search function to find some articles on these.
    I got new emulsion tubes and needles for mine from Mike's XS as well.
    '05 ST1300
      The XJ model has a different enricher/choke set up than the XS. Teh carbs can work, but it takes some rigging to make it happen from what I have read.
      • GARTHXS
        • 1631
        • Seattle
        fj1100
        Mine are off an 85 fj and they are sweet and pristine condition they slip right in the carb boots better than stock had to rig up a fuel T and I used an fj throttle cable and an ebay choke bar lever and it runs good
        91 kwaka kz1000p
        Stock
        ( Insert clever quote here )
        • tarzan
          • 1700
          • Chandler,Az.
          If you search around a little, a couple people have retrofitted carbs off completely different bikes.Maybe it was ZR1 carbs?I cant remember,but you should be able to search carb swap.
          Rick
          80 SG XS1100
          14 Victory Cross Country
            Peter
            Hi Peter,
            as posted, several different carbs can be made to fit, some more easily than others.
            There's even a list member installing a fuel injection system on his bike.
            What I'd like to see is a 4-way inlet manifold with one horkin' great carb on the end of it.
            No more frustrating attempts at balancing 4 carbs.
            • Crazcnuk
              • 2980
              There is a kit for Viragos to do this. You replace the two Hitachi carbs with 1 Mikuni.
              It would be interesting, but as with anything to do with carbs, cost prohibitive.
              '05 ST1300
              • tarzan
                • 1700
                • Chandler,Az.
                There us a guy on another forum that built and intake out of abs pipe for plumbing.It is on a Virago and he is using one carb.
                It would be cool to build a manifold for an XS so you could use a progressive two barrel.
                80 SG XS1100
