new member pics
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    new member pics
    Here's the pics of Phyllis I promised.I hope we did it right.This is my 1st try at posting pics.
    Terry
    1980 special (Phyllis)
    1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
  • DJinNH
    • Mar 2008
    • 854
    • New Hampshire
    Hey Terry, your's looks just like mine and Gary F's bike.
    Hope you get a lot of enjoyment out of it.
    Don
    currently own;
    1980 Yamaha XS1100 SG
    2009 Yamaha Star Raider
    • tw1980
      • Apr 2009
      • 662
      • Bend OR
      Yeah they could almost be triplets.Great looking bikes you guys have.Thanks for looking. Terry
        • 6751
        Very nice ride Terry...I especially like the red brake calipers and the SS brake lines...all in all she is a sweet one
        1980 XS650G Special-Two
        1993 Honda ST1100
          Hey Terry,
          You got the linked thumbnail as well as a URL link posted, but IF you want the photos to show full size directly in your post, then you want to copy what Photobucket shows as the IMG tag, then paste it in your message, you don't have to use the Insert Image button because Photobucket puts them in the link they provide already, and then they will look like below!
          Just put a carriage return/..hit the ENTER button to create a new line before posting the subsequent photos, otherwise, they will end up SIDE by SIDE instead of stacked atop each other, causes too much side scrolling!
          Very Nice, pipes, drilled rotors, etc.!!!
          • 79XS11F
            • Jul 2006
            • 3563
            • Ottawa, Ont. Canada
            Thats a good looking bike... If running real well what carb jetting you using with the POD air filters?
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • tw1980
              • Apr 2009
              • 662
              • Bend OR
              to 79xs11f
              1196 kit,mega cycle street/strip cams,dyno jet carb kits,ported head,jardine 4-1 exhaust.dj 140 main,2nd slot needle,4 full turns on pilots.Good idle and low end,a little lag mid throttle at 5000 to 7000 rpm,and supper hot full throttle 6000 to 8500.I'm going to try dj 144's later this week.I'll keep you posted if you like.
              Terry
              • 79XS11F
                • Jul 2006
                • 3563
                Ya keep me / us posted. I will so have my 1179 kitted bike ready to tune. It's a 78 standard that is similar but I don't have hot cams. Did you also do the valve springs and if so where did you get them. Same for cams?
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                • tw1980
                  • Apr 2009
                  • 662
                  • Bend OR
                  Thanks topcatgr58
                  Thanks for the complements and the tips on posting pictures.I know when we do it wrong we make it harder for you.You guys are great. I'm looking forward to meeting some of you at rallies this year. Terry
                  • tw1980
                    • Apr 2009
                    • 662
                    • Bend OR
                    to 79xs11f
                    Mega Cycle somewhere in CA. I got the cams reground to to different specs and hp valve springs. The gal that answers the phone knows her stuff and can answer a lot of questions. If you can't locate them email me and I will have my wife dig up the records from last year and get you the the number. I should know more on the carb tuning next week, will advise. Terry
                      • 7605
                      Terry, At 4 turns out, I would go up one size on the pilot jet. For the mid-range lag, run it there for about 30 seconds, and chop the throttle to read the plugs. That should tell you if you are a little lean or rich. JAT
                      NICE looking bike!
                      Mega-Cycle is in The Los Angeles area. About 375 miles South of me.
                      • tw1980
                        • Apr 2009
                        • 662
                        • Bend OR
                        thanks diverray
                        I thought the same thing about the pilots but that is where dyno jet recommends to start.That is a great idea though to use plugs to get the mid range set,I'll pick up some new plugs and give that a try.thanks Terry
                        • tw1980
                          • Apr 2009
                          • 662
                          • Bend OR
                          79xs11f
                          Well Rob the 144 mains were slower than the 140's but there wasn't much difference,So I changed them back.This weekend I'm going to resync and put in some new plugs. Then I can read the plugs and get rid of that little miss I have at mid throttle.I'll post my findings on the tech forum when I get it 100 % right. Terry
                          • tw1980
                            • Apr 2009
                            • 662
                            • Bend OR
                            Thanks DiverRay
                            Ok I synced the carbs yesterday and the closer I got it to being right on the harder it was to keep it running.After they were synced the bike wouldn't idle worth beans.After getting frustrated a while I calmed down and remembered what DiverRay had said about the pilots.I readjusted them to 2 turns and she started purring.I think dynojet had a misprint when they recommended 4 turns on the pilots.That also fixed the stumble I was getting at mid throttle.So here is the settings I ended up with dj 140 main,2nd slot needle,1 3/4 turns 0n pilots.
                            Terry
                            • Crazcnuk
                              • Aug 2006
                              • 2980
                              • Hinton, AB, Canada
                              There are no 'turns' on the pilots. You are adjusting the idle mixture screws.
                              The pilot jets are on the inside of the float bowl behind the main jet, and they are not adjustable.
                              I think most XS11s have 42.5 pilots stock, while some of us have 45's stock.
                              '05 ST1300
