checking middle drive oil with no dip stick
  • yamaphil
    • 10
    • prince albert sk canada
    Hey, how does a person check the middle drive oil if you don't have a dip or miss placed it. Have anybody used royal purple oil? I just put ams oil 20W40 oil in my 78 xs 1100 and it seems to be treating well. thanks for help
    To check middle and final drive oil, I used a piece of paper and measured from the top of the oil line in the paper to the top of the drive just like the dipstick would. There is a tech tip on making the dipstick, it gives the dimensions from the top of the drive to the fluid level.
      If in doubt.. filler'up. Any XS will get blown out of the vent.
        • 6765
        +1 on that..its better to have way more than you need than to have too little...if the middle or final drive goes dry while you are running down the road...it could be a catastrophic failure and lock up on you...thus sending you to some impending doom...
        2005 Honda SilverWing 600
        2018 Honda PC-Xpress 150
        • CatatonicBug
          • 6117
          • Clinton, UT
          I used the tech tip to cut a new dipstick out of lexan, and I keep it in the toolbox under the seat. I believe you can still get them from Yamaha too, for under $10. Did you mean to say that you put 20W40 in the Middle drive?? I hope not. You need actual gear oil (most use synthetic here). I have read mixed reviews on the purple stuff, so I just go with normal stuff.
          • yamaphil
            • 10
            20w40 in the engine, not the middle drive. I used 10w40 last year and I found that my bike was running a lillte hot, and the heavier oil its seems to a lil cooler and a lil better on gas. thanks for you advice
            • Crazcnuk
              • Aug 2006
              • 2980
              • Hinton, AB, Canada
              Just drain it all out, put in the measured amount.
              Then watch ebay for a dipstick for the next time you want to check it.
              '05 ST1300
              • red bandit
                • 970
                • central michigan
                Bike Bandit used to have dip sticks for about $3.50. Don't know if they still do.
                79 SF parts bike.
                • DESTRO
                  • Apr 2009
                  • 13
                  • Las Vegas
                  Bike Bandit still lists them under;
                  SIDE COVER - TOOL
                  For a 1981(and maybe the others) the part number is 22811-001 $6.80
                  #46:
                  GAUGE,OIL LEVEL
                  (FOR MIDDLE AND FINAL GEAR CASE) [GAUGE,OIL LEVEL]
                    I'm using 20-50w Vavoline in motor, Royal Purple in middle drive and final drive. Did notice that wine from drives is almost non-existant.
                    • yamaphil
                      • 10
                      yeah, I just found out that they sold royal purple in NAPA my city and I was wondering how well it works. Thanks for your advice.
                      • Ivan
                        • Jul 2008
                        • 2524
                        • Hutchinson KS
                        Tod and I do the same method. If you fill the middle drive and final drive with the bike on the side stand, it doesn't overfill it too much. a bit of seepage and in a couple of days the car wash will take it off.
                        Ich habe dich nicht gefragt.
                        • mstic2000
                          • Aug 2008
                          • 574
                          • Saginaw, Mi
                          I just printed out the dipstick from here and then just used a popsickle stick (same length) and marked it off.
                          My 1978 http://img.photobucket.com/albums/v518/mstic2000/xs.jpg
                          • randy
                            • Dec 2003
                            • 4521
                            Hey, mstic2000, took a look at your photos. What's that you have going on with the rear brake? Looks like an interesting mod, care to share it with us?
                            • mstic2000
                              • Aug 2008
                              • 574
                              • Saginaw, Mi
                              PO installed a 1986 GSXR1100 rear brake caliper. Little bit better rear brake than the original. I still have the original I might switch back if I decide to go back to completely stock.
