If someone on the forum is looking for a Vetter fairing mounting bracket to fit an XS1100 there is one for sale on Ebay item # 290309854293
fairing bracket
hmm...
So does one Buzz Lightyear hold one side of the windshield and the other Buzz Lightyear holds the other side?-Do what makes you happy.
'79 Honda CB 750 K (2)
'78 XS 11 E - "Rhona"
...and a 2nd E, for the goodies on it. -
'81 XS1100LH (almost ready)
Previous ride:
'86 VF500F
'82 XJ650J Maxim
"That which doesn't kill you most likely will the second time." -Eugene Krabs-Comment
and just in case the Buzz Lightyears don't work... you can try this one...
Item number 290309834293
81 SH Something Special
79 SF MEAUQABEAUXS
81SH Nor'eas tah (Old Red)
80 LG Black Magic
78 E Standard Practice
James 3:17
“Alis Volat Propriis”
Yamaha XS 1100 Classic
For those on FBComment
Thanks Kat, it's getting so I can't read my own writing anymore.By the way everyone, I dumped those plastic Vetter windshield screws and nuts in favor of metal rivet nuts and Allen screws, so I wouldn't have to remove my CycleSound in order to remove my windshield for polishing or changing. If anyone is interested in doing that, I'll post some pics. and instructions.
Fastmover
lion". SHL
78 XS1100eComment
If you still want to use the plastic screws they make 8/32 rivet nuts. so you just need to use them instead of the 10/32's that I used, but I think he was worried about the windshield braking if bumped more then being tightened down to tight.Fastmover
lion". SHL
78 XS1100eComment
In an accident, the two upper steel clips are supposed to bend and release the upper part of the windshield and the lower plastic screws are supposed to break off, releasing the windshield. If the clips don't bend and the screws don't break, the windshield will not release and it could break in half. Either way it will create a instant guillotine out of the windshield and the fairing.
Losing a few cheap, plastic, screws can quite literally save your neck or, depending upon the particular style of aerobatics you are performing at the time of a kinetically-expedited dismount, a couple of other important parts.
Do not use steel screws to attach the windshield to the fairing, use plastic screws.
Regards,
Scott-- Scott
♬Comment
Thanks for the tip, However I seem to specialize in high-side crashes, where being beheaded by a broken windshield isn't a problem, but if I do decide to crash head on I'll keep it in mind.Fastmover
lion". SHL
78 XS1100eComment
For high-side dismounts above all go for form! Height, arc, distance, follow-through and penetration will appear to survivors and witnesses to flow naturally if one can simply maintain good form.
For low-side dismounts quote Shakespeare at the top of your voice as you assume the role of Puck. At high speeds try to get away from the bike for the straight and simple verse, "I'll put a girdle round about the earth in forty minutes!"
If possible, avoid the more prolonged, "I'll follow you, I'll lead you about a round, through bog, through bush, through brake, through brier...."
For the ride report: remember if you tried to slide or roll!
Regards,
Scott-- Scott
♬Comment
