fairing bracket
  • wa407mpp
    • Jul 2007
    • 717
    fairing bracket
    If someone on the forum is looking for a Vetter fairing mounting bracket to fit an XS1100 there is one for sale on Ebay item # 290309854293
    Fastmover
    lion". SHL
    78 XS1100e
  • Erik the Red
    • 422
    • Northern MI
    hmm...
    So does one Buzz Lightyear hold one side of the windshield and the other Buzz Lightyear holds the other side?
    -Do what makes you happy.
    '79 Honda CB 750 K (2)
    '78 XS 11 E - "Rhona"
    ...and a 2nd E, for the goodies on it.
    • wa407mpp
      • Jul 2007
      • 717
      I posted the Item# at the top of the page, if it didn't work look on the last page of the xs1100 parts site on Ebay.
      Fastmover
      lion". SHL
      78 XS1100e
      • BlackD1114
        • Mar 2009
        • 87
        • Toledo, Ohio
        No. You see, what happens is after you buy those buzz lightyear toys, the fairing stays up by "falling with style" (I really hope that at least one person gets that)
        '81 XS1100LH (almost ready)
        Previous ride:
        '86 VF500F
        '82 XJ650J Maxim
        "That which doesn't kill you most likely will the second time." -Eugene Krabs-
        • Wildkat
          XS Special Gurette
          • Apr 2004
          • 3416
          • Location, Location
          and just in case the Buzz Lightyears don't work... you can try this one...
          Item number 290309834293
          81 SH Something Special
          79 SF MEAUQABEAUXS
          81SH Nor'eas tah (Old Red)
          80 LG Black Magic
          78 E Standard Practice
          James 3:17
          “Alis Volat Propriis”
          Yamaha XS 1100 Classic
          For those on FB
          • wa407mpp
            • Jul 2007
            • 717
            Thanks Kat, it's getting so I can't read my own writing anymore. By the way everyone, I dumped those plastic Vetter windshield screws and nuts in favor of metal rivet nuts and Allen screws, so I wouldn't have to remove my CycleSound in order to remove my windshield for polishing or changing. If anyone is interested in doing that, I'll post some pics. and instructions.
            Fastmover
            lion". SHL
            78 XS1100e
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              I'd be interested, but doesn't Craig Vetter say to not use metal fasteners to at risk of damaging/breaking the windshield (and those things are NOT cheap).
              • wa407mpp
                • Jul 2007
                • 717
                If you still want to use the plastic screws they make 8/32 rivet nuts. so you just need to use them instead of the 10/32's that I used, but I think he was worried about the windshield braking if bumped more then being tightened down to tight.
                Fastmover
                lion". SHL
                78 XS1100e
                  Cy, it's not so much the windshield damage that's the problem, it's that steel screws work too well.
                  In an accident, the two upper steel clips are supposed to bend and release the upper part of the windshield and the lower plastic screws are supposed to break off, releasing the windshield. If the clips don't bend and the screws don't break, the windshield will not release and it could break in half. Either way it will create a instant guillotine out of the windshield and the fairing.
                  Losing a few cheap, plastic, screws can quite literally save your neck or, depending upon the particular style of aerobatics you are performing at the time of a kinetically-expedited dismount, a couple of other important parts.
                  Do not use steel screws to attach the windshield to the fairing, use plastic screws.
                  Regards,
                  Scott
                  • wa407mpp
                    • Jul 2007
                    • 717
                    Thanks for the tip, However I seem to specialize in high-side crashes, where being beheaded by a broken windshield isn't a problem, but if I do decide to crash head on I'll keep it in mind.
                    Fastmover
                    lion". SHL
                    78 XS1100e
                      Okay, high-side and low-side dismounts are entirely different than a soccer mom on a cellphone turning left in front of you and putting a smile through your face a la, "Batman: The Dark Knight" and "The Disappearing Windshield Trick!"
                      For high-side dismounts above all go for form! Height, arc, distance, follow-through and penetration will appear to survivors and witnesses to flow naturally if one can simply maintain good form.
                      For low-side dismounts quote Shakespeare at the top of your voice as you assume the role of Puck. At high speeds try to get away from the bike for the straight and simple verse, "I'll put a girdle round about the earth in forty minutes!"
                      If possible, avoid the more prolonged, "I'll follow you, I'll lead you about a round, through bog, through bush, through brake, through brier...."
                      For the ride report: remember if you tried to slide or roll!
                      Regards,
                      Scott
