heat gun
  • Yahman
    • Mar 2008
    • 779
    • Salem, OR
    I have used one of these from "Top Flight" for many years now and it still works great. You should be able to find one at your local hobby store.
    Larry
    82 XJ1100
    80 XS1100G (Project bike)
    64 Yamaha YA-6
    77 Suzuki TS-185
      I've got 3 name-brand grinders in a drawer (Milwaukee, Makita, Bosch), all with bad switches and the replacement parts are $25-40 each. The switches seem to last about 1-2 years..... do the math.
      '78E original owner
      Hey Steve,
      I had a cheaper 4" grinder that had a switch go bad. I bought another grinder from HF because they were on sale, but I also went to RS and got a 120V single pole, on/off switch and wired and zip tied it into place replacing the OEM switch. It works just fine, not as pretty, but stays on. IIRC, the older switch was a variable current style to allow variable speeds, but I rarely used it spinning slowly, so full speed gets the job done. I didn't know how to wire in a variable speed switch, nor could I find one, or at least an inexpensive one, vs. getting an OEM replacement like you quoted for $20-30!
      JAT! T.C.
        Originally posted by soccer4m
        Try Ebay,,,,they are all made in China no matter which brand you get. I got one for 14.00 and it works great. - - - ,Mike in S.Diego
        Hi Mike,
        not necessarily, some electrical stuff is still made in North America.
        Mind you, I was told that one particular item came in an orange case labelled "emergency" at $50, a gray case labelled "industrial" at $35 and a black case labelled "domestic" at $27. All the cases came out of the same mould and each set of innards was identical.
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          Hobby store
          I got a good one from the hobby store that is designed for shrinking the film on RC planes. Seems it was around $20 and has served me well for about 15 yrs now...
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
