Does anyone know where i can get a decent heat gun?Am looking to shrink wrap some wires on my SG and was wondering about if i need a really hot one or how much heat is required to heat shrink wrap?We had one at work but a supervisor used it once and never returned it.
heat gun
heat gun
1997 Jeep Cherokee 4.5"lift installedTags: None -
Thanks Alan-I'll try Walmart first.1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installedComment
Good ol' Harbor Freight tools will probably be cheapest. If you are going to use it commercially.. maybe not. But a few times now and then... probably be perfect for you.
http://www.harborfreight.com/cpi/cta...emnumber=66001
I wouldn't buy anything at Harbor Freight that says "Chicago Electric" on it - pure crap. I had one of their heat guns. Lasted for one use, then something fried inside and that was the end of it. I've seen many references to Chicago Electric on the web, and the consensus seems to be to stay away from it. Bought one at Ace Hardware that cost a few dollars more, but works every time I plug it in.I think I have a loose screw behind the handlebars.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
ebay heat gun
Try Ebay,,,,they are all made in China no matter which brand you get. I got one for 14.00 and it works great. They come with all the attachments and a nice plastic case to store the stuff in. Believe it or not, I use it for redoing the plastic faded bumpers on my 500,000 mile Toyota Previa. All of them are notorious for fading and I saw a youtube video, using a heat gun to semi remelt the plastic and they look like new. It works great. It has a high,med,low setting for different applications. So,,Ebay has various prices but they basically just heat and blow. Good luck,,Mike in S.Diegomike
1982 xj1100 maxim
1981 venture bagger
1999 Kawi Nomad 1500 greenie
1959 wifeComment
No, Chicago Electric isn't Snap-on or Craftsman.. but it's not meant.. or priced.. to be. I've bought a lot of C/E stuff that is one-time or very infrequent use, and never had any problems except for a grinder I bought. BUT.. Harbor Freight is also great about taking stuff back.. (like if it only worked once)... and replacing it hassle free.
Paying more doesn't necessarilly mean trouble free either. I've had plenty of problems from Black and Decker, Dewalt, etc.. Most of the time I kind of expect problems, and buying stuff on Ebay that you may have to return.. can sure be a hassle.. along with extra or lost shipping fees for exchange.
SO.. Yeah, their stuff is usually pretty cheap.. but it usually works well for the average guy for a long time still.
I agree with Tod. I have used some harbor freight stuff with good results. And I have never had a problem with returns there either.Harry
'79 Standard
'82 XJ1100
'84 FJ1100
Acta Non VerbaComment
Yep,
I got one of the C/E heat guns from HF last year, has worked just fine for many heat shrink applications and such! Has 2 temp settings. YMMV!
I will say the 50 foot blue PVC 3/8" air hose I got last year is already bubbling and leaking!
HF was having a sale on GoodYear hoses, so I bought a 50foot black one of those, hoping the goodyear brand quality of rubber will last a bit longer than the other Chicago Pneumatic stuff I got from there!
I've bought lots of stuff from Harbor Freight, and for the most part I've been very happy with the purchases. They have a lot of hand tools that work well, and they have budget-priced torque wrenches that also work well. I've got the 50' hose from Harbor Freight, and it works great. Needs a dryer on the end for paint work, but any hose that long probably has the same issue (condensation inside the line). Also bought a hose real from them for the 50 footer - it's a good quality reel that also works well.
My problem with their Chicago Electric brand tools, is that they just aren't made very well. Their power tools use a lot of plastic, often in places subjected to stress. I thought I was safe with a heat gun, as it has very few moving parts, and low and behold the moving part was what broke. The element still got hot, but the fan no longer turned. Maybe I just got a bad one, but that experience put me off CE. I still go to Harbor Freight for lots of stuff, but if it plugs into an electrical outlet, I go someplace else.I think I have a loose screw behind the handlebars.
I have a Makita heat gun that produces up to 2kw of heat over 5 heat settings and 2 fan speeds.
As an electrician I use it on a daily basis for heat shrink and many other uses, including plastic welding (with the right adaptors). It was at the more expensive end of the price range but i've had it for 6 years and never had a problem with it, and it's still a current model.
I tend to buy tools in the higher price range and I generally don't have to replace them very often. Some of my stuff I still have, and use, from my apprenticeship days over 30 years ago.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
I use a Milwaukee variable temperature heat gun, with a dial for setting anywhere from 212 degrees to 1100 degrees. Yes, you can solder with it, and it does a great job for heat-shrinking, especially with the various nozzles it comes with for concentrating the hot air stream. Not cheap, but a great example of "you get what you pay for".Ken TalbotComment
I'm with Tod on this one. A rule that I use for buying at HF is if the item is 1/2 or less in price compared to a 'name' brand, you'll do ok as far as value.No, Chicago Electric isn't Snap-on or Craftsman.. but it's not meant.. or priced.. to be. I've bought a lot of C/E stuff that is one-time or very infrequent use, and never had any problems except for a grinder I bought. BUT.. Harbor Freight is also great about taking stuff back.. (like if it only worked once)... and replacing it hassle free.
And I actually like their small grinders; catch 'em on sale for $20, they last 1-2 years usually (and I sometimes use these pretty heavily) then throw 'em away. I've got 3 name-brand grinders in a drawer (Milwaukee, Makita, Bosch), all with bad switches and the replacement parts are $25-40 each. The switches seem to last about 1-2 years..... do the math.
One thing to be careful of though; a lot of HF tools aren't OSHA legal, so it's not a good idea to take 'em to work.
'78E original ownerFast, Cheap, Reliable... Pick any two
I've had really good luck with stuff from Northern Tool. Their prices are competitive, and even their Northern Industrial house brand is pretty decent quality. Here's a link to their heat gun page - http://www.northerntool.com/webapp/w...atchallpartialI think I have a loose screw behind the handlebars.
78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
