"Hey you... yeah you, Lard Ass!"
  • #61
    Yep doing forms is a REAL work out if you put effort into them. As to sloww..well...back in my lifting days I had a friend with an olympic set who bet me he could kill me by having me lift just the bar for curls. He had me count slowly to ten lifting it up and again going back down like two seconds for each count. By the time I hit fifteen reps my arms were ready to fall off.
    • #62
      Originally posted by kjohnson View Post
      Yup, that is what the specialist said. I have another sleep study on the 13th (2 months in a row with friday 13's) to try one out. The trouble then becomes, if it works, my benefits better cover it otherwise I can't get it. The cost is extraordinary.
      Hey Kevin;
      Good luck with the follow-up study. Definitely sounds like 'sleep apnea' and, if that is indeed the case, the CPAP should work wonders with you.
      Here's a link for you (for Alberta) S.A. Resources & CPAP coverage assistance , which will provide you with some information on treatment as well as coverage for the CPAP machine and other areas of assistance.
      The negative effects that Sleep Disorders have on the human body can be as bad as and, in some cases, worse than that of being overweight, poor diet, lack of exercise, lack of sleep, etc. and, in fact, can be the cause of these things which are blamed partly or wholly for the disorders themselves.
      If the diagnosis is confirmed and, you are able to get the treatment required, you'll feel like a 'new man' in no time. Good Luck!
      Ron
      1980 XS11 LG (Diablo)
      1980 XS11 G (Bagger)
      1978 XS11 G (White Knight)
      1978 XS11 G (Skeleton)
      2016 SS (S.S. Flyer)
      • #63
        Kevin, definetely get and use the CPAP machine, if you can swing it. I have one and use it every night. I was in the same boat as you, needed to lose a few pounds, but had no energy. Found out I had Apnea and was prescribed a CPAP machine. What a huge difference! You won't know how bad you felt until you get a really deep sleep.
        It did take a little while to get used to it. It is very quiet, and my health insurance actually rents the machine. They are billed monthly. Most insurances do cover it. Many people lose weight just by using the machine and getting proper rest.
        Hope this helps, Mike
        1982 xj 1100 pod filters
        4 into 1 Supertrapp
        • #64
          Hi Kevin,
          the lowest CPAP price I found on the 'net is $999.
          A recent TV ad claims a funeral can cost $10,000.
          Me, I'd find the $999.
          • #65
            Not a real chicken or egg situation.
            Hey Kevin,
            Regrettably it was the excess weight that caused you to develop the Sleep Apnea condition! Yes, normal weight people develop SA, but it's very prevelant for overweight folks to develop it.
            Dieting alone is definitely not an answer. The body has maintainance set points in it's metobolism and such. When folks take a drastic cut in their caloric intake, the body thinks it's starving, and resets it's points even lower, so then after folks stop/fall off the diet, they then return to the previous caloric intake levels, but their setpoints don't reset back higher, and so they use even less energy, and more gets stored in the fat cells.
            That's why increasing activity is so important in being able to start the body towards loosing weight, resetting the set points. IT also helps retrain the body into being able to perform the transition from SUGAR metabolism that's in the muscle tissue into fat conversion metabolism, the ole hitting the wall syndrome folks talk about. Then modest cutbacks in caloric levels help to futher aid in the weight loss process without the body feeling that it's starving. Also starting slowly with exercise is very important so that you don't start trying to use too much muscular activity without the required additional circulation the muscles need. If you try to do too much too soon, then the muscle don't yet get enough Oxygen, and they turn to ANAEROBIC (no oxygen) respiration, and this is what creates LACTIC ACID in the muscles which makes them get SORE, and also contributes to folks falling off the exercise regimen so early! Don't get too hung up on the weight loss part for quite a while. The idea with exercise is also to increase muscle mass, and muscle is much more dense that fat, and so with increased muscle development, you may actually not see as much or as quick a loss in weight, BUT you should be able to notice a reduction in body dimensions as the excess fat tissues are reduced as you build muscle. And increased muscle mass increases your metabolism, and also burns up more energy, so the more muscle you develop, the more fat you will be able to burn.
            Water Aerobics are good, but depending on the time you have in your schedule, can be bothersome having to get changed, then get wet, exercise, then dry off, get changed again, and then go home! IF your knees are in good shape, just walking, not even running can be very beneficial. Again just starting out slow, only 10-15 minutes the first day, and then add 5 minutes every day till you get to 30 minutes. Then you can increase your pace, so that you can increase your walking speed, ever see those speed walkers, yes they can look a little funny, but they are not pounding their joints anywhere as much as actually running/jogging. Get a Walkman/MP3 player, really helps to pass the time. Take your bike/car and drive a circuit around your neighborhood to map out a 3 mile route. At first, you will just divide the time you will be walking going on the route 1/2 the time you have alloted, then 1/2 way back, and then you will go farther everyday. Eventually if you get up to actual jogging speed, you'll make the 3 mile distance in about 30 minutes. At least 3 days a week, but you may find you can do more as you get more into shape. 5 days a week would be better, allowing for rest/fun on the weekends!
            Good luck getting the Cpap, and get out there and be Xcessive!!
            • #66
              Aerobic vs. Anerobic Exercise
              TC I dont completely agree on what you term as anaerobic respiriation. My understanding is that exercise that is Anaerobic in nature means physiologically that amount of muscular exertion can be accomplished without the maximum uptake of O2 that is incurred under Aerobic conditions. It is always Anaerobic that goes first. A good example of an anaerobic exercise would be an athlete who is say a 100 yard dash sprinter.He does not go into Aerobic respiration until he has finished the sprint and O2 debt has caught up with him.
              A marathon runner is an example of Aerobic exercise where O2 debt has long occurred and your heart and lungs must maintin homeostatsis at the elevated levels you are running at...in otherwords you try to acclimate to a steady state condition between exercise and heart and respiration but that is soley aerobic in nature. BTW You are correct that lactic acid is the biproduct of muscular exertion. We get sore because the muscles lose their elasticity due to lactic acid build up...Stretching exercises alleveiate the lack of elasticity and help breakdown the lactic acid...thus alleviating those aches.
              1980 XS650G Special-Two
              1993 Honda ST1100
              • #67
                Don't get me wrong, I a m trying. That is what the 4-6 hour of Taichi a week it for. I don't have the room to do more Taichi at home and it is dangerous for a newb to do it on snow/ice. I can do the Taichi foundation exercises, but they aren't quite as good a workout. I also take my hyperactive puppy outside to play and run/walk.
                My big problem is motivation. I have very little. My wife who sat me down to proclaim that she is sick of being fat is no motivation to me as all she still does is overeat and sleep. Just because she is pregnant and "eating for two" she thinks she needs to eat like two. Most of my family seems to have little interest in motivating me and the only friend I have that is close to me make me look like an Ethiopian.
                I just don't know how to find time in the day to do all that I want to do, exercise, work, eat and sleep.
                K. Johnson
                -1978 XS750SF - brought back from the dead with carb
                triple clean and boots
                -1982 XJ1100J - brought back from the dead by
                replacing motor after throwing #4 rod
                -1985 XJ750XN - shim job, oil change, ride. not bad for
                $500 including new rear tire.
                • #68
                  My 2 1/2 cents CDN
                  As always, Kevin, there is lots of experience and good advice on this site. My story is I was in the best shape of my life at 49. SWMBO had complained for years about my snoring and interupted breathing while I was asleep. My Doctor made an appointment at a sleep clinic and the waiting list was 6 months. While waiting for the appointment I had two coronaries and stints installed. As it turned out I did need the machine, and have used it ever since(even napping).
                  My best advice is do what you need to do to get the machine if you need it. It can only help you.
                  Walking is stongly advocated by physicians and patients alike. Start out with short walks that you are comfortable with and lengthen them as you are able. I found right after supper before the tiredness sets in works best for me. Take your dog with you and keep the routine. Your dog will learn the pattern and encourage you to keep the routine.
                  Lastly, Try to maintain a positive atittude. Easier said than done I know but a little success goes a long way. Good Luck, Rick
                  I May Be Crazy, But I Have A Good Time.
                  Northern Gypsy - 2010 Kawasaki Concours 14 ABS - Daily rider
                  • #69
                    Kevin I am sorry to hear that your family is lacking in support and motivation for you. Ultimately it comes down to yourself as most everything does. You have to motivate yourself...but take exercise with the frame of mind as being recreational...not as some dreaded physical activity for which you have little motivation...Personally my favorite activity is on my bicycle a Mtn bike I ride around in a huge park...Its agood aerobic activity that will burn lots of weight off and gives you a chance to get outdoors and moving in the world. Its easier than running as there is no punishing or pounding of your body against gravity...
                    First off get your sleeping issues straightened out...then and only then should you embark on a physical regimine. At that point you will need to build your strentgh and endurance. To do so you have to establish certain levels of exercise. You must know your limits and know at what point you need to progress to the next level.
                    I used to be a marathon runner back in the 70's but mostly recreationally not competitively and also I was a Phys Ed major 3 years before I switched to Rehabilitation...
                    So I would encourage you to FIND some time as with anything if you cant find the time then you wont get very far. YOU hold the keys... not your wife or anyone else You can do it if deep down in your soul that is truly what you want. I believe you can! You need to as well. Taichi is a very good idea and is meditative. Mental discipline and spirituality and OFC being a physical discipline as well.
                    The key to good health is threefold...diet ,exercise and a positive mental/spiritual attitude.
                    I hope I am not sounding like a preacher but these are my experiences and I am hoping you could benefit from some of it.
                    1993 Honda ST1100
                    • #70
                      - - - My big problem is motivation. I have very little. My wife who sat me down to proclaim that she is sick of being fat is no motivation to me as all she still does is overeat and sleep. Just because she is pregnant and "eating for two" she thinks she needs to eat like two. Most of my family seems to have little interest in motivating me and the only friend I have that is close to me make me look like an Ethiopian.
                      Hi Kev,
                      Three things to do:-
                      1) Chuck out all the fatty food in the house and put your wife and yourself on a low fat high fibre reduced calorie food regime as you do aerobic exercises together.
                      2) Raise hell with your doctor about fast tracking you a CPAP machine.
                      3) Hmm, what was 3? Oh yeah, cut back on the self-pity.
                      • #71
                        Got another sleep study with the CPAP on March 13th to see if it will work for me. It seems to take a heck of a lot longer to get anything done medically in Alberta since we started to "boom" and everyone and their dog moved here. It took me 6 months to get the first sleep study in the first place. I miss being able to phone my doctor on a Tuesday for an appointment the next day. Now I'm lucky to get in within the next month.
                        K. Johnson
                        • #72
                          It's not just a lot of hot air!
                          Hey BNE,
                          I haven't studied all of the finer details of human metabolism, the Krepps cycle, etc., like my wife the nurse had to, but what I'm saying is that AEROBIC exercise is what a person does ie. running, swimming, etc. which causes the heart rate to accelerate to around 120-140 bpm, about twice the resting state. When a person is properly conditioned, then while they are performing this exercise, they are able to intake the needed amount of oxygen, AND are able to circulate it to the muscles doing the exertion in quantities adequate to MAINTAIN proper metabolic processes....Aerobic respiration. And as long as the muscles are getting adequate OXYGEN they will metabolize the sugars and such and don't create lactic acids. BUT if a person is not in shape/conditioned, and is not able to supply the muscles with the required oxygen, then the metabolic processes change the type of chemical reaction that is occuring in the mucles so that it can still generate the required energy to keep working, but the byproduct of this lack of oxygen metabolism=anaerobic respiration is the lactic acids, and they accumulate within the muscle tissues, etc.!
                          So..like you said, as long as the person is able to have a homeostasis with the oxygen intake and the demands for it by the muscles, then they are performing AEROBICly, but if they increase their activity beyond the ability to supply the required oxygen, then the muscles will convert to performing ANAEROBICly, and that's when they get lactic acid build up, soreness, etc..
                          So...Kevin, I don't doubt that TaiChi is a decent exercise, but is it stimulating your heart enough to EXERCISE it? Yeah, ya gotta motivate yourself, as well EDUCATE your SWMBO regarding her caloric intake, she just needs to eat a healthy diet, not for 2! Back in the late 50's my mother was put on a DIET, not allowed to gain more than 20 lbs, I still came out at 22" and ~7 lbs.
                          The key word in what you said earlier was "morbidly" obese, as in Morbidity, a term we in the health field use for talking about DEATH statistics!
                          • #73
                            Hi Kevin,
                            lucky you! in Saskatchewan it's at least a 2-year waiting list for a sleep study.
                            And lucky me, It only took a week after a routine check-up to get sent home with a computer and an oxygen uptake monitor to record how well I did overnight.
                            (It seems I didn't quite need a CPAP machine)
                            But that quick, easy and low cost program has since been abandoned by the geniuses who run Sask Health and I hope they choke in their sleep.
                            • #74
                              the strange thing is, 10 years ago a person at the same height/weight as me was only considered overwieght. needed another 50-100lb to make them morbidly obese
                              K. Johnson
                              • #75
                                Ok, after "researching" BMI a little more (never looked into it as I had no use for a system that puts my dad as overweight when he has to run around in the shower to get wet and couldn't gain weight if his life depended on it) and I only fall into the obese category. Morbidly obese is 2 steps up yet. Makes me feel a little better. Maybe my doc was trying to scare me into loosing weight?
                                K. Johnson
