Can anyone tell me how to bypass a knock sensor on a 98 Chey truck with a 350 motor? Can you just unplug it or does it have to be grounded? It is just a one wire plug. I don't think a new one would help, because i think i have some piston slap when it is cold. The truck has about 280,000 miles on it but still runs great.
Truck related
Look here:
http://www.automotiveforums.com
If you register you can search for that knock sensor. A bunch came up for the Silverado when I did.Richard -
On the older systems with ESC you could unplug them, but I think the later stuff used a bias voltage on the wire so you may get a check engine light when disconnected. Either way, the ecm will ignore the signal and revert to base timing. If you get an improvement in performance, you'll know that is the problem.
Honestly, I have never seen a knock sensor that worked well enough to do what they say it should do. The test procedure is to tap the engine block near the KS and watch for timing retard. Most of the time they just don't work. A co worker in a shop I worked at kept hitting it harder and harder, finally breaking the coolant jacket. Boy was the boss happy.
Just be ready for the Knock Sensor to not be your problem, although it definitely could be.Ich habe dich nicht gefragt.Comment
If the knock sensor isn't working, would it help to install a doorbell instead?
(Sorry, I had to...)1980 XS850SG - Sold
-H. FordComment
Doorbell
Canatonicbug
I would still need the wiring diagram for the doorbell, unless you want to come up and wire it up for me. How does your xs get around in that 6 to 8 inches of snow you got.
Thanks Tom
82 XJ DAILY RIDE
78 XS1100E FIXING UP
79 XS1100F PARTS BIKE
79 XS1100SF NAKED BIKE
80 XS1100SG FULL DRESS BIKE
82 XJ IN THE ROUGHComment
To the OP, FYI, if you can afford a new truck, Ford is darn near giving them away.
Three weeks ago, I bought this '08 F-150 with the Triton 5.4, 4x4, cloth seats, back up sensors/alarm if you get too close to something, power windows/locks for $22,000.
I traded in a Dodge Ram after nearly wiping out in snow and ice. I bought the Ram in St. Pete, FL and figured 2 wheel drive would be fine.....then I moved back to NH and realize it wasn't.
Doncurrently own;
1980 Yamaha XS1100 SG
2009 Yamaha Star RaiderComment
Yeah, this snow SUCKS!! I've been riding up until it hit last weekend, and all this week I have had to take the cage to work. Luckily, the schools were closed for 2 days this week, so SWMBO didn't need the car (she's a teacher). The temps are supposed to get up to 50 tomorrow, and highs in the 40s all next week, so hopefully I will be able to ride again next week, once the snow melts a bit more.1980 XS850SG - Sold
-H. FordComment
