I have figred out what is wrong with all your bikes. Every one of them!
Gremlin Bells, maybe.
There's a difference:
A Gremlin bell will fix bike problems.
A cow bell is what my last date should have worn around her neck."Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy) -
Pro.. you sicko!
Did the farmer tell you to have her back in the barn by sunset so nobody would try to "Tip" her? (For those that don't know what cow tipping is... look it up)
Should have got along well with her.. a bale of hay is what.. 4-5 bucks? Cheap date. Was it that she had four nipples to just your three that bugged you? Sounds to me like you missed a good thing. All that body heat during the winter, free methane... just back her up to the candles and get those sporadic bursts of heat. Then, when you either tire of her or warmer temps arrive, you can simply "Divorce" her.. then cut her up and put her in the freezer without the cops coming to snoop around like the last time... AND you don't lose half your stuff!
K. Johnson
-1978 XS750SF - brought back from the dead with carb
triple clean and boots
-1982 XJ1100J - brought back from the dead by
replacing motor after throwing #4 rod
-1985 XJ750XN - shim job, oil change, ride. not bad for
$500 including new rear tire.Comment
When a 10 isn't enough, get a 11. 80g HardbaggerComment
