engine polishing
  • petejw
    • 2269
    • sydney australia
    engine polishing
    Have just started to polish the engine
    and thought id stick a cpl of pics up,
    I grounded down the raised castings
    i also grounded the edge of the alt cover and casing flush which
    gives the look of a machine finish.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    I ground down this... I ground down that... Blah, blah, blah.
    (I've got a grinder and files...)
    I wanna know how, and with what, you polished the engine!
    • Wildkat
      XS Special Gurette
      • Apr 2004
      • 3416
      • Location, Location
      It's looking good Pete...
      I need to start working on mine pretty soon... keep posting pics...
      It gives me incentive...
      81 SH Something Special
      79 SF MEAUQABEAUXS
      81SH Nor'eas tah (Old Red)
      80 LG Black Magic
      78 E Standard Practice
      James 3:17
      “Alis Volat Propriis”
      Yamaha XS 1100 Classic
      For those on FB
      • tarzan
        • 1700
        • Chandler,Az.
        It looks like you opened a can of worms there.Looks nice though.How long did that area take?Are you going to keep re polishing it or seal it somehow?p
        80 SG XS1100
        14 Victory Cross Country
        • petejw
          • 2269
          • sydney australia
          that area only took a cpl of hours but i had to strip the paint off first, i wont seal it, ill just keep polishing.
          I used the brown and white rubbing compounds on a dremel and a bench grinder.
          heres a link to the uk site where i did a write up.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • petejw
            • 2269
            • sydney australia
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • xs11lover
              • 1433
              • Montoursville Pa
              wew, looks like alot of hard work. Are you going to do the front?
              79 XS11 Special (Lazarus)
              79 DT 100
              • 79XS11F
                • 3563
                • Ottawa, Ont. Canada
                I use BRASS wire wheels that are ether on a hand held drill or on a bench mounted grinder. Glass beading is also a good place to start. After all the oxidation is removed the alloy can be polished with power tools and or by hand with any number of products. Pick your products with care however to make sure they are PH balanced for alloy and do not contain ammonia. The results will be dependent on how much time you want to put into it.
                Rob
                KEEP THE RUBBER SIDE DOWN
                1978 XS1100E Modified
                1978 XS500E
                1979 XS1100F Restored
                1981 Suzuki GS1100
                1983 Suzuki GS750S Katana
                1983 Honda CB900 Custom
                • jjwaller
                  • 242
                  • Gautier, MS
                  Ot
                  Completely OT
                  Welcome back Prom!!!!
                  John
                  '81 CB900C ( 10 Speed)
                  '78 CB750F ( The F)
                  '76 CB400F ( The Elf)
                  New '82 Honda MB5 Ring Ding
                  Then: '76 CB550K
                  '78 CB750F
                  '84 VF1100S
                  And still Looking!
                  • XJOK2PLAY
                    • 2099
                    • Skiatook, Ok.
                    John,
                    I don't think you saw the post date... 1/5/09.
                    Haven't seen Prom around here since he went through all that a while back.
                    2011 Kaw Concours 14 ABS
                    • jjwaller
                      • 242
                      • Gautier, MS
                      John,
                      OOps. Didn't notice this was a resurrected thread.
                      Still miss you Prom. Sorry.
                      John
                      '78 CB750F ( The F)
                      Then: '76 CB550K
                      '78 CB750F
                      '84 VF1100S
                      And still Looking!
                      • webbcraft2150
                        • Sep 2002
                        • 1605
                        • AUSTIN.TX
                        I guess if ya can't ride it, might as well polish it.
