coaxial cable
    • 2072
    coaxial cable
    Hello- i was wondering if coaxial cable is cheap to buy?I need like 25 + feet because i live in an apartment and the cable company wants like $52.00 per hour to fix an outlet in my bedroom.I figured because i have a splitter for my cable modem and cable box i could just get a longer cable.I have a 12 foot cable now and it is working but it is going across the room.I need excess cable to go around the wall.
  • earl G
    • Aug 2007
    • 461
    • allentown,pa
    home depot, if you have 12 ft , buy a connecter and maybe 15 ft. i would look inside outlet box first, sometimes they just disconnect spitters.
    80 xs1100G
      • 2072
      Cable in my bedroom is broken.Can i repair this?It is missing wire in the center.
      • earl G
        • Aug 2007
        • 461
        • allentown,pa
        yes install a new end priece,or pull the old one off, you have to cut back the outer part of the cable,the black not the wire, pull wire back,cut white to get to center wire, need about 3/4 inch
        80 xs1100G
          • 2072
          If i do it then i have to crimp on a new end.Correct?Can they be obtained from Home Depot?
          • earl G
            • Aug 2007
            • 461
            • allentown,pa
            yes they have everything with pictures.
            80 xs1100G
              • 8797
              F connector
              They even have the screw on type F connectors. No tools needed, 'cept for a knife. Not as good as the crimp type, but they work fine.
                • 2072
                Right now i have a 2 way splitter connecting 2 cables together.Is this ok-it works.
                  • 8797
                  You should be ok like that, but sometimes the computer cable modems will act a bit wonky when they are not fed the proper signal stregnth, DAMHIK.
