The NEW XS11.com Site and FORUMS!
    #136
    Hey there Craz,
    Those types of things are in the programming of the software that we are using, so we can't change it. Regrettably, just need to remember that once you POST your reply, and then you want to edit/make changes, you will want to SAVE your changes vs. re-posting it! You could create your post in Notepad, review and edit it, and THEN copy and paste it into the REPLY window! JAT!
    • Crazcnuk
      • Aug 2006
      • 2980
      • Hinton, AB, Canada
      #137
      Then why the heck is that button there at all?
      it's not like you CAN post a reply while your in the middle of editing...
      I find it a MAJOR PITA.
      '05 ST1300
        #138
        It's one of those things that people try to figure out why the programmer did that. I do that to people all the time
        • Crazcnuk
          • Aug 2006
          • 2980
          #139
          You mean like anything microsoft does?
          '05 ST1300
          • JWSanders
            • 879
            • White House, TN
            #140
            Can I suggest that, if possible, you remove the 'post reply' button on the message edit page?
            I end up typing all my replies 2 or 3 times because I hit that stupid post reply button instead of the tiny, pale SAVE one!
            Well, there is actually a little bit of control that is available for the layout with these forums. I'm making this post so I can edit it and see what you're talking about.
            Edit - Ah, I see what you're talking about. When you go to edit a reply you're most likely that last one who has posted to the thread. Since it edits the post in place, what you're seeing is the bottom "Post reply" button that is there on all thread pages. If you hit the "Go advanced" button before editing it will bring up the full text editor on it's own page, eliminating the confusion. There may even be a preference for that. I'll look it up.
            80 XS1100SG
            81 XS400SH
            Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
            A Few Animations I've Made
            • DeanR
              • Jan 2005
              • 1499
              • Finger Lakes NY
              #141
              I asked this once before but don't recall a response (probably the memory). On my ST forum that also uses this software, you can hover over a thread title and it will show you the first sentence or two without having to open the thread. YERY handy when catching up on threads to quickly see if it is of any interest or not, but we can't do that here. Can that feature be turned on?
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
              • JWSanders
                • 879
                • White House, TN
                #142
                Hmm, I do remember that. It was hovering over the entire pane rather then the title though, and was a bit annoying (that's why it was turned off). It appears to have gotten lost in the shuffle. I'll see what I can do.
                80 XS1100SG
                81 XS400SH
                • DeanR
                  • Jan 2005
                  • 1499
                  • Finger Lakes NY
                  #143
                  Thanks JW. If it works pretty much the way it does on the ST forum, I think folks would find it very useful.
                  80 SG
                  81 SH in parts
                  99 ST1100
                  91 ST1100
                    • 8929
                    I found that hovering feature very annoying when it was turned on in the beginning. JMHO
                    • DeanR
                      • Jan 2005
                      • 1499
                      • Finger Lakes NY
                      #145
                      Maybe it worked differently here, because in no way is it annoying on the other v bulletin powered site.
                      http://www.st-owners.com
                      It's only there when you want it to be for easy quick scanning of threads titles.
                      80 SG
                      81 SH in parts
                      99 ST1100
                      91 ST1100
                      • JWSanders
                        • 879
                        • White House, TN
                        #146
                        Luckily, others had found that annoying as well, since there was a fix for it on the vB forums, There hadn't been before.
                        I have turned it back on. Now, instead of hovering the preview over the whole frame the thread title is in, it will now only pop up when you hover over the thread title itself.
                        We'll let it run for a while and if there's issues we can go from there. I can see where it would be handy...
                        80 XS1100SG
                        81 XS400SH
                        • DeanR
                          • Jan 2005
                          • 1499
                          • Finger Lakes NY
                          #147
                          Yep, that's it JW. Thanks !!!
                          80 SG
                          81 SH in parts
                          99 ST1100
                          91 ST1100
                            • 8929
                            Yep, it's ok now. Just the way it was in the beginning with boxes popping up all over the place was a pain, but with it only on the thread itself is just fine.
                            • dbeardslee
                              • Nov 2007
                              • 4385
                              • Maineville, OH
                              #149
                              Link Text Formatting
                              In the old interface you could insert a link and also format the text that would show up in the post. I've seen several posts with the link text formatted, but darned if I can figure out how to do it with the new interface. Anybody know the secret?
                                This kind of text formatting or formatting the link itself? http://www.xs11.com/forum/showpost.php?p=202175&postcount=149
                                Nope, no idea....
                                Regards,
                                Scott
