Headlamp Modulators?
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    Ernie I hope you know that they are NOT legal in ON
    Hey Carl,
    This may shine some light on the legality debate http://www.tc.gc.ca/roadsafety/mvstm...ev4_e.htm#_Toc specifically section 7.9.4
    Ernie
    • olebiker
      • Aug 2007
      • 692
      • Kingston ON
      Ernie all that did was give me a head ache. Can you translate that for me? I thought that the province had control over lighting?
      http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
      • egsols
        • Jan 2006
        • 1090
        I dunno, but me thinks Transport Canada has more authority then the provinces. Mind you I am only assuming that based on the hierachy of Government I learnt back in school, however, you know what happens when you assume.
        I believe what they have done is that since they are allowed in the States then we have adopted the same ruling so that any bikes with them on can be legally imported into Canada.
        The Highway Traffic Act states "Alternating highbeams on other vehicles prohibited.....
        (2) No person shall use highbeam headlamps that produce alternating flashes of white light on any vehicle other than a vehicle referred to in subsection (1). R.S.O. 1990, c. H.8, s. 169 (2)."
        Vehicles in section 1 are emergency vehicles.
        So....I guess the feds say its okay to bring them in but the Province says okay but don't ride em.
        Anyway I've sent the MTO a note asking for their clarification. Where's the smiley for "holding my breath"
        Ernie
        • xs11jack
          HALF GURU
          • Nov 2002
          • 606
          • O'Fallon, Mo.
          Prices
          I just looked up the two semiconductors in my Jameco.com catalog. One costs 78 cents and the other, 35 cents. If a heat sink is called for that is the pricey item, running as high as $2.50.
          The rest of the components are cheaper than the semiconductors.
          So, just get a small piece of breadboard and solder away!
          J.D."Jack" Smith
          1980G&S "Halfbreed"
          1978E straight job
          "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
          Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
            • 6762
            Originally posted by egsols
            madmax-im,
            You're right...my suggestion is ridiculous....I wasn't serious.....I just remembered years ago when a certain make of bike had bouncing headlights which weren't originally designed as a safety feature
            yeah I remember those bikes with the shaking headlamps tooAlso the link for the HM at JC Whitney looks pretty good too!Thanks!
            persona non grata
              • 6762
              Originally posted by strippedFJ
              Here's a schematic for a simple and cheap headlight modulator for those interested in building their own.
              Parts should be no more than $10 retail.
              There you go! Now thats cool...I have lots of experience with electronic components....great info..Thanks!
              persona non grata
              • strippedFJ
                • Aug 2008
                • 77
                • Australia
                No worries mate, enjoy electronics myself. Still have to pull finger and finish my electronic dash unit, but I'll get there.
                One point to note that may affect the arguement for the Canadians. The circuit that I pointed to allows you to select the low beam only, or both beams, depending on how it is wored in. If only low beam is selected (which would be my choice) then the headlight modulator should be legal. ie "Alternating highbeams on other vehicles prohibited....."
                  • 6762
                  The diagram also allows for it to be wired to the high beam only..if you want....at any rate there should be a switch to turn it on/off...regardless of how you wire it up...realizing the illeagality of it north of the border...but down here not sure...during the daytime I run with my highbeams all the time...so a HM for me might be better wired to the highbeam....hmmm maybe I'll jus wire it to both As for how this unit modulates...Is it in the ideal range as mentioned (in the link for the schematic)concerning how many times it flashes in a given minute?
                  persona non grata
                  • strippedFJ
                    • Aug 2008
                    • 77
                    • Australia
                    Should be, but if you don't like it try changing the resistors connected to the 0.1 uf capacitor at the bottom of the schema, they should affect the on-off cycle rate.
                    I have not built this circuit myself, might give it a go this week, if I do I'll play with the resistors and let you know which one affects what.
                      • 6762
                      That would indeed be of interest! Be interesting to see how small it can be made too.
                      persona non grata
                      • ClarkGriswald
                        • Aug 2008
                        • 256
                        • Bloomingdale, MI
                        Never forget you can always build something better yourself than things that are mass produced. You can optimize something to be its best rather than how it will be assembled and how fast.. Im all for building stuff.. interesting thread.
                        XS1100 F/G (79 Bike/80 Motor)
                        Grab a tetanus shot and jump on!!!
                        • Pat Kelly
                          • 3046
                          • Golden Valley, AZ
                          Why not wire a turn signal flasher into the low beam circut. RLU will engage the high beam as the low beam cuts out. Add a by-pass circut around the flasher to turn it off at night for a continous beam.
                          Pat Kelly
                          <p-lkelly@sbcglobal.net>
                          1978 XS1100E (The Force)
                          1980 XS1100LG (The Dark Side)
                          1999 Suburban (The Ship)
                          1994 Dodge Spirit (Son #1)
                          1968 F100 (Valentine)
                          • egsols
                            • Jan 2006
                            • 1090
                            Hi Pat,
                            Good thought.....these are the sandards though...
                            S7.9.4.1 A headlamp on a motorcycle may be wired to modulate either the upper beam or the lower beam from its maximum intensity to a lesser intensity, provided that:
                            (a) The rate of modulation shall be 240 ± 40 cycles per minute.
                            (b) The headlamp shall be operated at maximum power for 50 to 70 percent of each cycle.
                            (c) yadda yadda yadda bla bla bla
                            Ernie
                              • 6762
                              Hi Pat...an interesting idea...never thought of that one...gonna consult some ppl on how this could be done...
                              persona non grata
                              • DJinNH
                                • Mar 2008
                                • 854
                                • New Hampshire
                                These things seem like a pretty good idea. I definitely see them coming from a distance...it's hard not to look at it at first.
                                I'd put one on my bike but it took me so long to get the fuse/wiring to work for my headlamp that I am going with the attitude, "If it ain't broke, don't fix it."
                                Don
                                currently own;
                                1980 Yamaha XS1100 SG
                                2009 Yamaha Star Raider
