Headlamp Modulators?
    • 6762
    Just curious if anyone has a HM on their XS or XJ?I have seen these on various other makes and years of m/c's.I have yet to see one on our older machines.
    There is some controversy over the good and the evil of using a HM...so how do you all feel abt them?
    Personally I would like to add one to all of my bikes.Having bright lights on your bike only does so much.These days almost evryone has daytime running lamps...so whats to distinguish a car from a m/c? A headlamp modulator would give a m/c that distinction.I have seen bikes approach me from 1/2 mile away with a HM flashing...its eyecatching... almost immediately you see it and you see it early...something abt pulsating light just grabs your attention
    persona non grata
    • 7724
    The big reason I've NOT put one on is the cost. Around here, they want $120 for the little bit of silicon that modulates the light. I KNOW it's only about $10.00 worth of parts, and I don't think I want to make someone that much money that fast. I will probably build my own on down the road, but only if I DON'T convert to a HID lamp. I know the modulators will not work with HID technology.
    JMHO
    • psycoreefer
      • Feb 2008
      • 1557
      • Minden, NV
      I want one, but price has kept me from getting one. I like the idea. Go for it.
      1979 xs1100 Special -
      My Bike:
      [link is broken]
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        i bought one from jc whitney for not that much, however i had to return it after it malfunctioned in 3 or 4 months, i now have hid which more that compensates....
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • SiP
          • 438
          • Medicine Hat, Canada
          Try flicking up and down with your thumb, it'll do the same thing, you'll get a work out and have spent no $'s
          Si Parker
          '81 XS1100H
          Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay.
            • 6762
            Si...I have done this but there are times when your attention is focused on the situation in front of you.It isnt always that easy to just flick the hi beams up and down...a modulator will do this for you ...it is also a wise idea to have a sw. that can turn it off too.
            I would not shy away from the expense of purchasing a HM...its money well spent and could really make the difference in being seen.
            persona non grata
            • egsols
              • Jan 2006
              • 1090
              • Barrie, Ontario, Canada
              You can make one for next to nothing....just need a special headlight and two bolts, two nuts and two lock washers....locate the headlight adjusting bracket and install one bolt, washer and nut throught the slot above the headlight adjusting bolt...install other bolt just below the adjusting bolt....then loosen the adjusting bolt slighty.....voila....now when you ride the headlight will bounce up and down attracting all sorts of attention (just like they used to on some of the older bikes, you know which ones I mean)
              Ernie
              • strippedFJ
                • Aug 2008
                • 77
                • Australia
                Are they metric compliant for us Aussies?
                  • 6762
                  Ernie...while I am never one to refuse a method to save money...I have to say that this isnt even close to what I had in mind...actually I think its kinda ridiculous...no offense and I appreciate all suggestions...but I dont want to drive around with a loose headlamp bouncing around.Granted in the daytime it wouldnt matter but after dark...you want the proper focus of light ahead of you and not bouncing all over the place.
                  I'm interested in saving money but I'm not a cheap bastard when it comes to my safety..so this idea is getting tossed.
                  I understand that alot of us ride these bikes because we cant afford to buy new...but it seems to me that some of us are just plain cheap/frugal with our money.
                  persona non grata
                  • egsols
                    • Jan 2006
                    • 1090
                    madmax-im,
                    You're right...my suggestion is ridiculous....I wasn't serious.....I just remembered years ago when a certain make of bike had bouncing headlights which weren't originally designed as a safety feature
                    Ernie
                    • egsols
                      • Jan 2006
                      • 1090
                      Found this...looks pretty inexpensive....http://www.jcwhitney.com/webapp/wcs/...1#BVQAWidgetID
                      Ernie
                      • strippedFJ
                        • Aug 2008
                        • 77
                        • Australia
                        Here's a schematic for a simple and cheap headlight modulator for those interested in building their own.
                        Parts should be no more than $10 retail.
                          Knowhow
                          Ray sez:-
                          "Around here, they want $120 for the little bit of silicon that modulates the light. I KNOW it's only about $10.00 worth of parts,"
                          Hi Ray,
                          there's the story of someone querying the $120 the Irishman billed him for removing the dent from a boiler:-
                          "To whacking your boiler one time with a sledgehammer to pop the dent out, $10.
                          To knowing exactly where & how hard to hit the bastard, $110."
                          It's not only the parts that you are paying for, it's also paying for them knowing how to make those $10worth of parts modulate your headlight.
                          • olebiker
                            • Aug 2007
                            • 692
                            • Kingston ON
                            Ernie I hope you know that they are NOT legal in ON. I asked the cops last time I was chatting with them. They think it is stupid as well but you can be charged.
                            http://farm2.static.flickr.com/1241/1480921818_241eade448_s.jpg
                            • psycoreefer
                              • Feb 2008
                              • 1557
                              • Minden, NV
                              StrippedFJ - thats a cool page. Who knew you could build one that easily.
                              As for the price I think your mostly paying for all the hoops that a manufacturer has to jump through to get DOT approved to sell these things as street legal. Ya know testing and such.
                              My Bike:
                              [link is broken]
