I took the Octopus off the carbs to make dis-assy and re-assy easier...but I'll be damned if i can figure out what goes where...is there a routing diagram for the '82 XJ1100???I am rather frustrated with this PITA...need some help fast...
G...Damned Octopus!!!
"I don't have a vacuum hose diagram..."
TRBIG can mock me and question my gender-orientation...due to the multi-colored display of fingernail polish in my toolbox...
"But they're "Fabulous" for marking vacuum lines and wiring connectors!" (And I have colors to match all my outfits, too!)"Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy) -
Well after pulling my hair a little...I calmed down and got it sorted out....got the bike to fire up and its sounding reaal going for a tes ride to se if all cyls' are firing...Thanks for the suggestion on the nail polish good idea...next time..LOL2005 Honda SilverWing 600
2018 Honda PC-Xpress 150Comment
Octopus ...
Geez .... My desire to keep things 'factory' was finally overtaken by the frustration of reattaching the tank and hoses each time after removing it. I've had to have the tank off ALOT. So I finally chucked it even though it works perfectly... if you do decide to chuck it however, be sure your fuel taps don't leak. Don't ask me how I know.
80G Mini-bagger
Past XS11s
79SF Squared-off Special, Vetter/Bates tour pkg., Mikes XS coils, G rear fender and tail light. Sold June 09Comment
I'm glad I have your permission at least.... because I do. And will!!TRBIG can mock me and question my gender-orientation
It wasn't so much the nail polish though, as it was the high heels and fishnets. Not bad legs by the way.. if you'd just shave them a bit. This isn't France or Germany ya know...
The absolute best way to ensure that you don't have any problems with the octopus is to REMOVE IT AND NEVER, EVER LET IT GET NEAR YOUR BIKE AGAIN!!! If your floats and needles are working correctly, you don't even need to worry about remembering to turn your petcocks to the OFF position when you aren't riding...
Hi...my name is Mike, and I'm a lane-splitter.
'80 XS1100SG (mine)
'87 CMX450C Rebel (daughter's first bike)Comment
Re: "I don't have a vacuum hose diagram..."
Gee thats niceOriginally posted by prometheus578
Getting in touch with your feminine side...The ladies will like that
d*mn the "octy"!!!!
hey there folks...hear ya about that d*mn octy......fubar'ed beyond all belief....tried 2 help a member here and ran into more probs with the octy than doing the actual job intended......would rather give birth than have 2 f*ck with that thing again......JMHO...talk 2 ya later.....ross
rebel devil
1979 xs 1100f standard
authenic historical vehicle
42°36'23.52"N, 82°52'44.78"W
"I'M IN MY HAPPY PLACE"
"i got 14 jobs mon....you only got 1 job....you lazy bones mon"
"if you don't wrench on it, get behind me satan!"
'96 venture cct.....installed!
stainless, braided, pvc coated brake lines
i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....Comment
KISS the octy goodbye
I have to admit that as my XS11SG had it's octy removed by one of it's dreaded POs I have no first-hand experience of the critter. But I have seen the drawing of how to hook it up. Not wanting to brag, but I had 45 years experience as a machine designer and the first thing you learn is the KISS principle. Anyone who uses nine hoses to connect two taps to two carb. inlet tees could never even have heard of it.Fred Hill, S'toon
"The Flying Pumpkin"Comment
I happen to like octopie
Octopie be your friend.
So I've started a non-profit octopus reserve for all the neglected and abused octopie out there.
Please send me (working or not) any you should no longer want around and I will put them on.....er in the reserve
mro
BTW
have three specials...no octopus problema's
81 don't count as it looks like parts
Thing is my Octy works ok...but when you look at that part of the bike you see hoses going around the pod filters and its unsightly...not to mention what a PITA in reconnecting it.Removing the carbs and working on them was easier and less aggrevating than reconnecting the Octy!
So according to what TC told me.I need to cap off the front port on the petcock on the right side and run the gas line with a filter from the rear port of the petcock to connect to carbs 1 and 2 on the left side of the carb bank...and the left side petcock is capped in the front and the rear is routed to carbs 3 and 4...sounds really easy
I got so frustrated with my fuel lines kinking right at the base of the petcock. There's just not a whole lot of room for them. So I bought some higher quality fuel lines, at least I was told they were higher qualitiy. They are blue and clear. Who knows....
Anyway, I had to rig them to go around the boots to the airbox. Looks like a freaking nest under there but you can't see much once the tank goes on. They all connect to the octopus. At least it solved my kinking problem. I just hope I didn't fix one problem while creating another....you know, like a major fire hazard.
Doncurrently own;
1980 Yamaha XS1100 SG
2009 Yamaha Star RaiderComment
".... got so frustrated with my fuel lines kinking right at the base of the petcock. There's just not a whole lot of room for them. So I bought some higher quality fuel lines, at least I was told they were higher qualitiy. They are blue and clear. Who knows.... "
I sure know this story well. Actually been through the fuel line colors and qualities too. Easiest to work with comes in 1 foot lenghts from MikesXS. Pretty sure it's close to factory .. it makes tight bends well. Black only
Once I get this motor dialed in, I may put the damn thing back on. I like the idea of automatic fuel shut-offs alot. Have forgotten a couple of times and contaminated the oil ...
I think I have seen here some pretty sharp XSers who say that the float needle and seat should hold the gas back anyway .... but I have not found that to be so .... I wonder if I still have float levels too high ?? Anyone know??80G Mini-bagger
Past XS11s
Hey Wiz,
I think the later styled Viton(rubber) tipped valves are more forgiving and seal better, vs. the older styled ALL METAL ones. The metal ones need to be an EXACT match to make and keep a good seal, whereas the viton ones have some compressibility to allow them to squish against the seat opening, and I think make a better seal, or at least have a better chance of making a tight seal even with slight irregularity or crud getting in the fuel!! I think this is also why Jessie/XS81Project came up with the Viton float valve conversion for the earlier bikes!
T.C.T. C. Gresham
octopizzy
if only they moved the seam on the bottom of the gas tank like... 1/4 in. further in, you could scavenge some vacuum petcocks from a smaller Maxim or a seca... For that matter, why didn't Yamaha put vacuum petcocks in there? Would've been better looking and easier to deal with... but nooooo they had to put a weird ugly thing in there.
'81 XS1100SH "Hound of Basketville" - new project
'81 XS1100H Venturer
'81 XJ750RH SecaComment
