fuel pump upgrade
  • DeanR
    • Jan 2005
    • 1493
    • Finger Lakes NY
    fuel pump upgrade
    Anyone ever seen or heard of this fuel pump (upgrade) kit?
    ebay Item number: 130239438692
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • The Lorax
    • Jun 2005
    • 1048
    • Riverside, OH
    Never heard of it, never heard of a motorcycle with vapor lock either. I had a car that used to vapor lock consistently, it was old, had a mechanical fuel pump and was a piece of crap. I guess if one really wanted an electric fuel pump, one could put it on, but is the pressure more than the needle valves can hold back? I know, that ad says it won't cause flooding, but who really knows. I certainly could be mistaken, wouldn't be the first or last time but it seems a little suspicious to me, a useless trinket if you will. just my humble opinion, someone, anyone feel free to correct me. have a nice day and ride safe
    I am the Lorax, I speak for the Trees
    '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
    '79 XS1100 F R (IL Barrachino)
    '00 Suzuki Intruder 1400 (La Soccola)
    '77 KZ400s (La Putana)
    • Dennyz
      • 1151
      • Olympia, Washington
      Snake oil!
      DZ
      Vyger, 'F'
      "The Special", 'SF'
      '08 FJR1300
      • jeffe
        • Oct 2004
        • 393
        • Westerville,Ohio
        I've never had gravity fail yet.
        78E ... Gone but not forgotten
        2006 Kawasaki Concours....just getting to know it
        • kjohnson
          • Aug 2007
          • 202
          • Wetaskiwin, Alberta, Canada
          I find that gravity flows more than enough some times and have never had a problem. I wonder how many would be fooled tho...
          K. Johnson
          -1978 XS750SF - brought back from the dead with carb
          triple clean and boots
          -1982 XJ1100J - brought back from the dead by
          replacing motor after throwing #4 rod
          -1985 XJ750XN - shim job, oil change, ride. not bad for
          $500 including new rear tire.
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            This thing came up on the forum a week or two ago and was deemed probable BS then. I see no advantage to have a fuel pump on a gravity system unless you can burn so much fuel under WOT that gravity cannot keep up. Certainly has'nt happened to me yet.
            Mike Giroir
            79 XS-1100 Special
            • planedick
              • Mar 2005
              • 2068
              • Yorba Linda, California
              Pump
              The FJ1200 I'm working on has a fuel pump. Same carbs as the XS1100.
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
              • 81xsproject
                • 3185
                • Fortuna, CA
                Snake oil, seconded.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                • LoHo
                  • Sep 2002
                  • 1342
                  • Fresno, CA
                  The test is simple:
                  A: Fill the tank, and run WOT as fast as you can. See how long it takes to empty the tank.
                  B: Fill the tank, set the petcocks on prime, and pull the fuel lines loose. See how long it takes to empty the tank.
                  Anyone wanna bet on "A"?
                  • DavesXS
                    • Jun 2008
                    • 231
                    • Matthews, NC
                    Originally posted by LoHo
                    The test is simple:
                    Be sure to video that test for us.
                    I am wondering where your going to WOT non stop untill the entire take is gone
                    My bet is B
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      I would say the test would be more accurate if you set it to prime and opened the bowl drains.
                      You could maybe pull off the WOT test in UT or NV. We took a trip out the 50 a couple months back. Went 90 the whole way and never saw a cop.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                      • TADracer
                        • 1417
                        My bet is B
                        I have to go with B also. The motor will not use fuel faster than it can drain from the tank. I did a test before installing my in-line filters. ONE cock drained 12 ounces in 15 seconds. Consider there are two on the tank and I am sorry, the motor just will not drink up 24 ounces of fuel in 15 seconds at WOT.
                        BTW, did the test with and without the filters (Russell 40 micron). They had no effect on the fuel flow at all.
                        Mike Giroir
                        79 XS-1100 Special
                        • AlanB
                          • Oct 2006
                          • 705
                          • Scotland
                          Hi Guys,
                          When I fitted modern carbs to my SG, I changed the cocks to match the 8mm hose on the carbs.
                          When I tested the fuel flow, it was notably quicker with the fuel cap open; the limit to fuel flow on my bike was the tank vent!
                          However, the fuel flowed FAR faster than it could ever be used!
                          AlanB
                          If it ain't broke, modify it!
                          • egsols
                            • Jan 2006
                            • 1090
                            • Barrie, Ontario, Canada
                            12 ounces in 15 secs is 22.5 gallons per hour.
                            Travelling at 60 miles per hour and getting 30 miles per gallon would be 2 gallons per hour.
                            That's less then a 10th of what the lines can supply based on TADracer's results.
                            So if the bike can use it as fast as it flows then 22.5 gallons per hour at say maybe 10 miles per gallon would be 225 miles per hour!
                            Ernie
                            • LoHo
                              • Sep 2002
                              • 1342
                              • Fresno, CA
                              Geez, guys, that was rhetorical..."Anyone wanna bet on 'A'?" But thanks for weighing in.
                              I see fuel starvation threads on here periodically, and a kinked hose or other obstruction can make that happen. But guys who think the gas tank doesn't empty fast enough are dreaming...
                              Nice figuring, Ernie. Personally, I have never been able to break through that 200mph barrier.
