Oil Pan Anyone know if there Generic
  • Ljay40
    • Jun 2006
    • 149
    After 2 years the oversized (stripped threads)oil plug I put in from Napa wont tighten unless I remove rubber gasket In which I did now I have a good oil leak from the plug with a not so oh tight oil plug
    So Im gonna bite the bullet and replace the Oil pan
    Question is Does anyone know if all the oil pans of the XS1100 are the same size
    or are they year /model specific Im looking at grabbing one off of ebay I have a 80 special and the pan is off a 79 They dont know what model the pan came from
    hope someone can help
    thanks in Advance
    LjaY
  • John
    • 5117
    Any oil pan from the XS XJ 1100 will work. The XJ will have an extra goodie in them...it's an oil level indicator switch, but the switch will not work on an XS, because we don't have that ability.
      Usually doesn't work worth a crap in an XJ either!
      • Ljay40
        • Jun 2006
        • 149
        Thank You
        • boyat68
          • Oct 2007
          • 358
          • Virginia
          Ljay40:
          In the meanwhile why don't you wrap the threads with that plumbers vinyl thread tape, it will help seize the threads and seal the oil leak. This way while waiting for a replacement, you can ride the wind.
          • Jerry
            XS & TRUE XJ GURU
            • 3023
            • Elma, IA.
            All the XS11s use the same oil pan. Same size, same gasket. As noted, the XJ pan will also fit, but uses an oil level sensor that is not present in the XS11 pans.
            Jerry Fields
            '82 XJ 'Sojourn'
            '06 Concours
            My Galleries Page.
            My Blog Page.
