I would like to put a ME880 tire on the rear of my 78 XS1100E. The closest size to the 130/90 17 I am currently running is a 140/80 17. Is anyone running this tire? I am conserned about the swing arm clearance. Also is this tire a smaller diameter than the 130/90? Thanks.
Metzler ME880 tires
Tags: None
Thanks again
Well thanks for the link i like that idea once i Finish my bike i am setting that combo on itComment
Last tires I used were Metzler Laser up front and Metztronic rear. They worked very well from the start and held the twisties very good. After the normal 3 rears to 1 front I changed out for Metzler Lasertec front and rear. These are a matched set. They handle a bit better in the turns than did the Laser/Metztronic combination and seem to be wearing about the same. These are both V rated tires so that prolonged blast up to 140 that some riders like is not a safety problem.
I like them and would recommend them since it can cost a small fortune to do a bunch of tire testing.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
Metzeler Marathon ME880s
I ate a set of Metzeler Lasertecs last year, but boy howdy did they stick!
I replaced them both this year with the ME880s front and back. I will get more mileage out of these and will still get the peg dragging stick that I look for.
gregGone but never Forgotten:
1980 XS11SG - "Scorpion"
Current:
2006 Yamaha FJR1300A - "Orion"
2007 Honda CBR600RR - "Twitch"
"Life is not a journey to the grave, with the intention of arriving safely in a pretty and well preserved body; but rather to skid on broadside, thoroughly used up, totally worn out and loudly proclaiming:
WOW - What a ride!Comment
