Automotive AC question.
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    Ok, so call me a wimp. AC compressor died in my '95 Olds 88. Installed a "compressor delete pully". Thats all well and good till it started getting hot. Now I want it to work. I got a hot smokin deal on a compressor/clutch, oriface tube, accumalator/drier, condenser and install o-ring kit. The all the parts arrived today. The compressor says it is full of the right oil. What my plan is to install all of these parts and take down to my AC guy and have him suck the system down (leave it alone Prom!!!) and recharge it. Do I risk cratering the new compressor doing this?
    BTW, all these parts are new, no JY stuff.
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    "Caught off guard."
    Webbcraft... that alone was funnier than anything I could have written!
    • webbcraft2150
      • Sep 2002
      • 1605
      • AUSTIN.TX
      Yea, but I know your fingers were poised to strike. I could hear the gears turning in that twisted mind of yours all the way out here.
      There should be some kind of award, I left you speachless?
      • Incubus
        • 1003
        • Austin TX
        WC, Autozone has vacuum pumps in their free rental program. I'd put the Freon in myself, were it mine. I've done it couple times. You may need to have your friend get it to work. On old GMs you have to jump it electrically to get the new compressor to kick in. I'd explain that better, but it's been a while since I had to do it.
        Patrick
        XS11F (Incubus, daily rider)
        1969 Yamaha DT1B
          • 7807
          As long as you DO NOT turn on the AC until it's been recharged, you should have no problem. The clutch on the AC will keep it from turning. You can leave the wire off the clutch, just to be safe.
          • The Lorax
            • Jun 2005
            • 1048
            • Riverside, OH
            I did this job once, on a 92 lumina. didn't bother vacuuming the system, figgered the compressor would take care of that for me. Charged the system, worked fine except that the schrader valve leaked and let all the refrigerant escape. I am reasonably certain vacuuming the system was not the cause as it's not the first time that valve had stuck. would have replaced the valve, but the kid whose car it was set the darn thing on fire a few weeks ago and subsequently junked it....one less thing for me to deal with. that's all I got, have a nice day and ride safe.
            I am the Lorax, I speak for the Trees
            '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
            '79 XS1100 F R (IL Barrachino)
            '00 Suzuki Intruder 1400 (La Soccola)
            '77 KZ400s (La Putana)
            • Dragon Tamer
              XStremely XSive(Deceased)
              • Sep 2006
              • 426
              • Half way between Chili and Winter Wisconsin.
              The A/C unit will not start without a charge in the system. It is controlled by a pressure switch. Evacing the system is an absolute! If it is not done it causes more problems than I can list here. The main one of those problems that you will see right away is that with ANY amount of non-condensables (air) in the system you won't get as much "cold" out of the vents as you were looking for!!
              The Old Tamer
              _________________________
              1979 XS1100SF (The Fire Dragon)
              1982 650 Maxim (The Little Dragon)
              another '82 650 Maxim (Parts Dragon)
              1981 XS1100SH (The Black Dragon)
              If there are more than three bolts holding it on there, it is most likely a very important part!
