Re: Modification
I put in longer lines too, with the right petcock feeding the left carbs, etc. I can remove the hold-down bolt at the rear of the tank, block the tank up with a piece of wood, and sync it right like that without removing the tank at all.
Originally posted by prometheus578
With the now longer fuel hose, when working on the bike(Synchronizing carbs and such), one can remove the tank, turn it around and set it on the frame. Bike can still be run as the lines are still connected.
