I saw this thread, but then had to chuckle at seeing that it had 11 views!
So...since many folks apparently like to read EVERY THREAD no matter what the subject, I figured I'd add some info as to how this can happen to you!
When you send PM's, there are 4 check boxes at the bottom for several functions, one where it will send a copy to your SENT folder, and after a while, even though you may remove most PM's from your INBOX, IF you don't review/check your SENT folder, it can fill up considerably, and your allotment of 100 TOTAL messages no matter where they are can be easily reached!
SO.....folks, check your OTHER FOLDERS every once in a while, or UNCHECK the boxes that send copies if you don't really NEED to keep a copy of what you sent!
79SF "The Teacher" . . .basket case! History shows again and again,
They are going out tomorrow . I had my garage jammed with my two bikes and extra parts I couldn't even get to them until last sunday. Where are you in Texas ? Haha! just kidding.
BDF Special
