oil, what to use.
  • mrjohnson
    • Mar 2008
    • 1
    • mt. vernon, wa.
    oil, what to use.
    What kind of oil do you all use in your motorcy cles? I have a 1980 XS1100SG. I am currently using Mobil 1 15-50.
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    "Most don't care for the synthetics"
    A lot of us run Castrol GTX 20w50.
      • 2011
      You will find that most folks on this site like to do things as cheaply as possible. However with that said the oil for these bikes is still currently available from Yamaha.
      • 81xsproject
        • 3185
        • Fortuna, CA
        Does the Castrol not have the stuff that screws up wet clutches? I am tired of dropping almost $4 a quart for the Valvoline 4 stroke and am looking for a cheaper alternative.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          The bottom half of the API/ SAE round seal is BLANK, so it does not have any of the extra friction modifiers that are NOT recommended to use with wet clutches. It's perfectly safe!
          • Crazcnuk
            • 2980
            • Hinton, AB, Canada
            Canadian Tire (or any other handy brand) of 15w40 Diesel Low-ash, Severe service motor oil.
            '05 ST1300
            • red bandit
              • 970
              • central michigan
              Pennzoil 10w40. 5 qt. jug at Walmart $10. Works for me.
              79 SF parts bike.
              • thewiz
                • Oct 2006
                • 1115
                • Wilksboro, NC
                I like Chevron Dello or Shell Rotella 15w-40. When it's super hot out here, I've have even run their 40w.
                80G Mini-bagger
                Past XS11s
                  oil
                  Have went to using 20-50w Vavoline and as a result upper valve train noise is all but non-existant. Read the info in the oil thread and Pennz... is another one at bottom of list.......have also known for 20plus years when younger have seen oil galleys plugged or restricted from the parrafin base in this oil and Quaker state when rebuilding motors. Also have rebuilt motors that have had nothing but Kendall in them, and one particular 72 Vette that I brought home from Houston to rebuild for bro-inlaw had used Kendall only and it still had factory cross-hatch pattern in cyls. at 180,000 with no ridge so only did heads as SBchevys originally don't have valve guide inserts from factory. Compression was still up to factory specs. Have had other machine shop engine builders relay similar stories as to the lubricating qualities of Kendall oils. Not available here, seems to be only available in the South so I use the next best. Also Shell Rotella is right up there at the top too. Mobil 1 is at the top of list, but as a syn. oil some report clutch slippage under hard acceleration, so would not be my choice for a bike with a wet clutch.........just my 2cents.
                  • beegshot
                    • 85
                    • South Carolina
                    Reading your thread title as, "What do
                    you use?"
                    I buy the Yamaha Oil from the local dealership. Always have...always will. In a pinch, I'll add Castrol if I'm out of the Yamaha oil.
                    Robert
                    XJ1100 - Stock
                    XV750 - POS parts bike
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      just changed mine yesterday after 2300 miles, use autozone generic 20w50, i figure the worse oil is better than the best oil in 1978, 2.1 per qt that's around $8.40, and at that price i could even do that at 1000 miles, but i don't, it was ditry tho and the magnetic drain plug had some grit stuck to it
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                      • bigb9582
                        • Jun 2007
                        • 118
                        • fayetteville, PA
                        i use Shell Rotella 15w-40 in mine with no problems. a 4 quart jug at walmart is like 9 bux.
                        79 xs1100f- standard- $50.00 runner
                        • fvincent
                          • 115
                          • Syracuse, New York
                          Did my homework-oil
                          When I purchased my bike, the PO was using Mobile 1. Since then, Mobil has added friction modifiers not settling well with my clutch. I studied this subject for a month before changing and decided in the same direction as these guys. http://www.calsci.com/motorcycleinfo/Consumables.html. #1 was Shell Rotella-T Synthetic 5w-40 (blue container, not white), $13 / gallon at Wal-Mart. Bike runs like new. Only gets a little bauky around 100 degrees F. Stays clearer than before and shifts like a dream. I can't make it slip. As a side note, I did two years of work on big truck electrical systems recently, and 90% of the drivers use Rotella. In their words, "My engines last forever". I had to keep looking to find a driver that did not use Rotella. The link above is Motorcycle related and pretty good reading.
                          See the XSEASTers pretty soon!
                          Floyd '80G
                          • fvincent
                            • 115
                            Correct link
                            Somehow I included a period in the link at the end. Here's the correct one.
                            Floyd
                            • fvincent
                              • 115
                              Also
                              Also, according to motorcycle riding scientists, The purolator "pure one" oil filter, is the best in the world.
                              Floyd
                              Oh no! What have I started?
