RC planes
  • BrianB
    • 362
    • Idaho
    A Jet Turbine would be to cool. Too costly for me though.
    A trailer to pull behind your bike would also be pretty neat.
    1980 XS Eleven Special
    • JWSanders
      • 879
      • White House, TN
      Always wanted to but never found the time. When I was a kid, my neighbor was really big into it. He had a B-17 bomber that was baaaadasss. The fuselage would barely fit in his garage. The wings were removable and it had 2 engines built into each one. They looked like chain saw motors. I never got to see it fly, sadly. The details on that thing were amazing.
      It even had a bomb bay and controls to drop talcum powder filled bombs.
      80 XS1100SG
      81 XS400SH
      Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
      A Few Animations I've Made
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        The list..
        Hobbyman wanted a quick list so I thought I would post it here too.
        Magnum XL91FS, near new, w/ carbon fiber mount
        OS91FS Surpass, near new, w/ carbon fiber mount
        Webra 28 with muffler, screaming hot little motor
        Antique OS 60 FS with open valve train, weak rings, but runs good.
        Old McCoy 19, no muffler and no throttle
        Saito FA80 with one mount hole broken and no muffler, runs really strong.
        Bag of assorted 049 engines and accessories, fuel, glow clip
        42cc gas engine with electronic ignition and adjustable timing w/18-8 prop installed
        2 each Hitec Laser 6 radio systems complete, nearly new.
        Hobico mechanical retracts with Robart struts (Was on my P47 Thunderbolt)
        One Piper Cub 83” span with Magnum 80FS, Futaba 8 ch radio system, ready to fly.
        Field support box with power panel, fuel pump, starter, glow plug power, and drawers full of extra hardware.
        Covering irons, prop balancer, incidence meter, deflection meter, coverite iron temp guage…
        Lots of extra servo’s, both standard and giant scale, one gear servo for mechanical gear, battery packs, crystals etc.
        All packages will be packed with extra hardware like control horns, pushrods, links, servo horns, etc just to help me get rid of all the unlisted stuff one needs when building.
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
        • planedick
          • Mar 2005
          • 2068
          Big Super Cub
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          • kf4anm
            • Apr 2003
            • 363
            • Indianapolis
            bomber
            I have the taste for trucks instead. I currently have an electric and have had a few nitros in the past. I ran across this today and thought it was pretty awesome for a plane. Looks like 2 seperate controllers.
            • chip
              • Jun 2007
              • 36
              • poplar grove il
              R C
              I don't know if many of you have seen this yet.
              Thay make quarter scale gas V8 engines.
              http://www.conleyprecision.com/cars.htm
              • planedick
                • Mar 2005
                • 2068
                Other dimension
                Trucks are lots different than airplanes, but the most important is the up/down part. Trucks go right or left, but not up/down. The controller is 4 channel, 1 for elevator for up/down, 2 is for ailerons for wing attitude (banking), 3 is rudder or right/left and 4 is for throttle. You only need throttle and rudder on the truck.
                Drilled airbox
                Tkat fork brace
                Hardly mufflers
                late model carbs
                Newer style fuses
                Oil pressure guage
                • chip
                  • Jun 2007
                  • 36
                  • poplar grove il
                  That maybe true. But the trucks that I have seen have lights, turn signals, horns, engine sounds and rattle and smoke, and can hook, unhook, and lower and raise the legs under the trailer.
                  Just curious if anyone has seen or found a place that has R/C subs.
                  • BrianB
                    • 362
                    • Idaho
                    You would be surprised at how many features you can add to an airplane that will make them a scale replica of real planes.
                    I am not into Subs but here is some info for you.
                    • mro
                      • Oct 2005
                      • 4276
                      • Hayward, California
                      Just taking a look at this thread...
                      Now if you were allowed to add maybe something like a .22 caliber semi-auto (or several on one of the larger planes) and go for a real dog fight...I might like to give it a try.
                      mro
                      Think I may have attention deficit disorder.
                      • HobbyMan
                        MeatHead Idiot "GURU"
                        • Jul 2006
                        • 1801
                        • Colleyville, TX
                        I remember one time some guy brought out some junk trainers that he was going to throw away. People lined up on the sides of the field with paint ball guns. It was interesting to see that. Some of the rounds destroyed the planes and some just plastered them.
                        Acta Non Verba
                        • planedick
                          • Mar 2005
                          • 2068
                          Control line
                          RC trucks are more like control line airplanes. You can add lots of extra stuff, but you are still limited to 2 dimensional control. If you want real excitement, let a real pilot try to fly RC. As soon as the model gets in a position where it's comming at him, it's over. I once asked a real pilot about landing. I said, "When you make that final turn and line up on the runway, how long before you put the wheels on the runway"? He said, "Usually around 2 to 4 minutes". I said, "What if it was 5 seconds and to make matters worse, what if at that point you discovered that your rudder and ailerons were suddenly reversed?" He looked at me really funny and finally admitted that at best it would be a real rough landing. LOL
                          Drilled airbox
                          Tkat fork brace
                          Hardly mufflers
                          late model carbs
                          Newer style fuses
                          Oil pressure guage
                          • HobbyMan
                            • Jul 2006
                            • 1801
                            • Colleyville, TX
                            Pilots fly by "the seat of the pants" or so I hear. If they can't feel the g's, its harder to know how much input to give. I tried to get my father to fly but as soon as it turned around he couldn't do it. Also, he overcontrols because the only feedback he gets is visual. Its just like the Airline simulators. They even move, simulating pitch, roll, and acceleraton. RC planes give none of that. Thats kinda why I like flying them. You can do things that you would never do yourself. Flying inverted 6 ft off the ground is one of them.
                            Acta Non Verba
                            • mro
                              • Oct 2005
                              • 4276
                              Yea, like one second being squeezed into the seat and the next flung up aginst the restrants, seeing the horizon spinning around and puking in your face mask
                              mro
                              • chip
                                • Jun 2007
                                • 36
                                • poplar grove il
                                R/C
                                OR for more excitement try flying or be next to a beginer flying a heli. More than once we have had do dodge broken parts
