My tank has some paint chips on the top only. There are a few right by the crotch area, then two to the right of the tank chrome and a couple to the right of the tank chrome. I have put bondo on them with a popsickle stick and they are drying overnight.
What should I use next to sand and then seal those areas. The left and right sides of the tank have only 1 spot and I do not want to do anything there as doing so may cause the sides to look bad.
What should I use from primer sealer over the bondo? What should I use to sand? I had planned to paint the top area with a gloss black unless someone can suggest a maroon that will match up well. I am hoping a good rattle can paint will be okay.
Thanks. Deltysdal@aol.com
