Get blue off pips
  • Get blue off pips
    How do you clean the blue off your pipes and mufflers?
    Web site
    Heres a website with reviews on just about everything under the sun. http://www.webbikeworld.com/
    I've never found anything that will remove the blue. Thats why the mfgrs went to the double wall pipes. The pipes look cool blue I think. Kinda how they are spossed to look you know.
      As I understand it Blue is runing "rich" Gold Is running "lean"
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
        Hmmm Did I just learn something new? I had always thought blue was lean...
        XS 1100 LG
          Extremely fine micro-mesh (3600 - 6000 grit), like that used for aircraft windows, worked for me... The only problem with this is it removes the metal as well so you can't go too deep...
          Some have had pretty good luck with semi-chrome too...
          It all takes a lot of time and elbow grease...
          Of course... you want to make certain your carbs are proper... otherwise... all those hours you spent polishing them up... turn into more hours polishing them up... Dang it
          Long live the double walls!
          81 SH Something Special
          79 SF MEAUQABEAUXS
          81SH Nor'eas tah (Old Red)
          80 LG Black Magic
          78 E Standard Practice
          James 3:17
          “Alis Volat Propriis”
          Yamaha XS 1100 Classic
          For those on FB
            Wildkat,
            that micro mesh ur talking about,
            have u used it to polish the alloy
            and if so was it any good.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              I've used it to polish pretty much everything that isn't painted on both my FJ and my XS and it does an outstanding job bringing the metal back to life... I like to go for a mirror polish rather than the original dull brushed finish and it takes very little time once you get a good technique down...
              I usually start with the 2400 and work up to a 6000 working one direction with one grit and then working perpendicular to it on the next... this leaves a mirror shine that is absolutely amazing!
              Here's a link to some
              Here's some information on it... You might be able to find it for less cost somewhere else... I'm not certain on that... It can be a bit pricey... but it truly does a great job.
              Some have questioned that doing this opens the metal to oxidation... but I haven't had any problems with it...
              79 SF MEAUQABEAUXS
              80 LG Black Magic
              James 3:17
              For those on FB
                Thanx Wildkat,
                Ive been doing pretty much the same thing,
                polishing everything that i can, its almost
                becoming an obsession, lol,
                but doesnt polish alloy look much nicer
                than chrome, ive been mucking around trying to polish
                the fins on the side of the head, its getting there, but its
                fiddly work.
                ive been using 400wet/dry used wet with sum detergent,
                then stainless steel wool dry, then wet and then buffing
                to a shine, ive had pretty good results doing it that way.
                a good alloy polish will protect it from oxidizing,
                i havent had to much trouble keeping it shiny.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                  Re: Web site
                  [QUOTE]Originally posted by knarfie
                  http://www.webbikeworld.com/[/url]
                  You weren't joking about that web site,great link!!!
                  '80 XS1100 SG
                    I use this stuff called Mas or something close to it. Simichrome should work also. I would try to refrain from things that take the chrome down unless it is necessary. The paste polishes take a LONG time with lots of HARD work but in the end, the resuly is amazing. The blue will go away. Before you do that, you need to get your mixture squared away. Blue pipes is a symptom of too much heat usualy caused by a lean condition. My pipes were perfect untill I ran my bike with cracked intake boots. They durned gold, blue, then deep purple. I only had time to polish one header before I left for school
                    Acta Non Verba
                      Excuses, excuses...
                      Slacker! Man! I expected SO much more from you than this... not taking care of your bike before you left... what kind of XSive are you anyway?
                      Don't you miss being here and getting this in person?
                      Isn't the bluing a thermal reaction in the metal or is it strictly surface discoloration? To fully remove it... do you have to take off some of the surface metal? I have found that regular polish does a decent job of getting some of the discoloration off... but to really get the nasty stuff (it was already on the headers when I got them... I PROMISE)... I haven't found a much better way than the really fine micro-mesh... and a LOT of elbow grease... (something I need to restock as I am starting to creak in strange places...)
                      I'm all for anything that doesn't remove material... on the pipes (ahem... Tod)
                      79 SF MEAUQABEAUXS
                      80 LG Black Magic
                      James 3:17
                      For those on FB
                        Yes you are right but it is only on the very surface of the metal. And yes, suprisingly I would like to be home right now.
                        Acta Non Verba
                        • #13
                          Before and After
                          I took this pic after using the Micro-mesh on the #4 header today... The bluing in the pipes on Bag Lady is so bad it goes all the way down the headers to the bend that leads to the mufflers... #4 looked just as bad as #3 still does... but this will give you an idea of how good the micro-mesh is...
                          I started with a 2400 to get the really nasty stuff... but then went to a 4000 to avoid removing too much material...
                          79 SF MEAUQABEAUXS
                          80 LG Black Magic
                          James 3:17
                          For those on FB
                          • #14
                            Hey Pete... here's something else I did with it
                            Hopefully, the pics will do it justice...
                            I haven't finished it yet... but this was only 15 - 20 minutes of polishing yesterday afternoon...
                            79 SF MEAUQABEAUXS
                            80 LG Black Magic
                            James 3:17
                            For those on FB
                            • #15
                              Nice work Wildkat,
                              u can c a big difference on the exhaust.
                              I tried taking pics of mine the other nite,
                              didnt work out 2 well, ill wait 4 a nice sunny day
                              and take a cpl more.
                              I think its well worth the effort, when u get such
                              a good result.
                              Have u used any polish on it,
                              or is that just with the micro mesh?
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
