shortening windshield
  • DeanR
    • Jan 2005
    • 1499
    • Finger Lakes NY
    What have people found to be the best way to take a couple inches off a windshield ??
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    You can cut it with a jig saw of the right tooth count and then buff with very fine sand paper but I WOULD NOT DO THIS MYSELF. If you split the shield your Sh*t out of luck. If you really want it shortened take it to a plastic shop and have them do it for you. I know about this because I have fabricated lots of plastic items in my aquarium hobby and this stuff can get brittle with age and is unpredictable at best.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      slow but used a hacksaw blade, draw file to shape, and clean up the rough, be careful not to cut too much off, cut a little off at a time buffeting sucks (damhik), and if you change your seat the height or the density of the foam may change your relationship with the top of the shield, so plan for that change.
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
        Jig saw with a variable speed has worked okay for me. If you run the blade too fast, you get melting, and the kerf will actually seal itself up again behind the blade. Slower blade speed keeps the heat down, and allows the chips to clear the blade rather than melt. Put a couple of strips of wide masking tape down on both sides before you start, and do your layout on the tape. The tape under the saw will prevent the foot of the jigsaw from scratching the plastic.
          I was told to get a reverse/up cutting blade instead of down cutting, and have fairly fine teeth like for cutting metal vs. wood. I was cutting Plexiglass instead of LEXAN, and was still able to do a decent job, nice curved shape for around the headlight and all! Emory cloth can be used to smooth out the edge to a nice smooth finish. Good Luck!
          • mro
            • 4276
            • Hayward, California
            I wacked one of mine with a sawsall (32 TPI blade) and then used a oribital sander to clean up edge. Took about 15 minuets.
            Did not even take it off the bike
            mro
            • cdpruden
              • Mar 2007
              • 26
              • Redford, MI
              It's funny, I had just seen this article the other day:
              Please recheck the URL for the proper spelling. Or use our search box at the top of this page to find what you're looking for.
              I haven't cut mine down at all, though, I like it just the way it is
              '78E
              • Poprock
                • Apr 2005
                • 594
                • Oregon Coast
                shield cutting
                a bandsaw with a 12 tpi blade works well also. Masking tape is a great idea. It also helps keep the plastic safe from the table of the saw. A jitterbug sander works better for me than an orbital, being easier to control on the thin edge.
