E-bay full fairing
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    E-bay full fairing
    Just curious to know if the fairing I just bough on eBay was being sold by someone on this forum. It is made for the 750 so I will hope that I can make it fit my 791100. Has the screen, mounting brackets, radio,speakers and lighting that is listed as all working. I got it for 53 USD so it appears to be a good deal. It's a pafico classic model.
    Anyone have any experence with these ?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • 7765
    You will need the mounting bracket for the XS1100 standard. The bracket that is with the fairing probably WILL NOT work correctly on your bike. IIRC, the Pacifico Classic used the same mounts as the Vetter.
    • 79XS11F
      • 3563
      do you know if the mounting bracket is the same but bigger or would it be completely different
      Rob
      1978 XS500E
      1981 Suzuki GS1100
      • Jerry
        XS & TRUE XJ GURU
        • 3023
        • Elma, IA.
        Bracket for the XS 1100 has a 3-point mount; each down tube has a mount and the top of the mount bolts to existing holes in frame. The differences in mounts have to do with the placement of the down tube sections. I suspect the tubes on the XS 1100 are a bit larger and a bit wider than the 750. Top mount could probably be re-drilled or modified to fit, but bending / modifying the down tube mounts is a lot more work. Not impossible, but a lot of work. You would be best off finding a mount designed for the 1100.
        The Pacifico and Vetter mounts, at least the ones I have seen, are not the same. There was a kit available to adapt a Vetter to the Pacifico mount, but the company that made these went out of business after a fire in their shop. Have not seen a Pacifico Classic, so don't know about that specific mount, but would be very surprised if it was the same as the Vetter. The Pacifico and Vetter mounts used the same frame attachment points, but the part where the fairing bolts to the mount is different. You need to get a Pacifico mount; a Vetter mount would have to be adapted to put the Pacifico fairing on it. Again, adaption is not impossible, but would take extra work.
        Jerry Fields
        '82 XJ 'Sojourn'
        '06 Concours
        My Galleries Page.
        My Blog Page.
        • 79XS11F
          • 3563
          Ya .. the other option is to just make my own mount brackets from scratch but an idea of what they look like would be good. i will see what I get when it arrives. i am guessing that the fairing it's self will fit as they are likely all the same and not model specific ... i hope.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • wa407mpp
            • Jul 2007
            • 717
            fairing
            Could you post a picture of the fairing, maybe one of us have one on our bike already and could post some pictures of our mounts and some measurements so you can build your own.
            Fastmover
            lion". SHL
            78 XS1100e
            • 79XS11F
              • 3563
              I don'tr have it yet but here are 2 of the photos from the ad. I have no photos of the mounting hardware but the fairing came off a XS750
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • wa407mpp
                • Jul 2007
                • 717
                That fairing is not the same as mine, but here are some pictures of my mount maybe you can make out enough to see how to build one for yourself. Does your 1100 have the same attachment points on the frame? I'll try to draw it out on paper with the measurements this weekend and post the scan.
                Fairing Mount
                Fastmover
                lion". SHL
                78 XS1100e
                  • 7765
                  From the Photo, the Pacifico has a SHORTER distance on the fairing mount bolts. IIRC the Windjammer is almost 9" between mount holes for the fairing. My guess is if you can get one of the '78 fairing mounts, it could be modified with little problems.
                  If you have a welder, you can use angle iron for the fairing mount, and 1/4" flat stock to make the angle for the frame mount.
                  • 79XS11F
                    • 3563
                    My frame does have the holes at the top of the up tubes. I however have never mounted one of these full sized fairings and have never even seen hardware for the job. That makes in difficult to picture in my mind how it is done. From what I can make out in the photos from wa407mpp the bottom of the fairing is in line with those mounting holes? I don't know what I'm looking at in the other photos so it will be the upper front mounting that I have no idea about. It is coming with hardware so i will likely have a much better idea when i see it.
                    Rob
                    1978 XS500E
                    1981 Suzuki GS1100
                      • 7765
                      Rob,
                      The hardware will probably mount to the frame with hose clamps. That was the "fit anything" way of doing it.
                      The mount holes on the frame need a slot about 3/4" long for the mount. If someone can draw one up, you'll have a good idea of how it's supposed to mount. The bottom of the fairing should be about 1" ABOVE the mount holes.
                      ------------------------------------| angle iron
                      ------------------------------------| Flat stock
                      | O | mount tabs
                      Side view
                      _________________________
                      |_________________________| Angle Iron
                      |-----------| Flat Stock
                      \ \ Flat Stock
                      | | top of mount slot
                      | | Mount tab
                      |_|
                      It's hard to draw in this format!
                      • planedick
                        • Mar 2005
                        • 2068
                        • Yorba Linda, California
                        Mount
                        The mount is in the picture at left of the fairing.
                        Drilled airbox
                        Tkat fork brace
                        Hardly mufflers
                        late model carbs
                        Newer style fuses
                        Oil pressure guage
                        Custom security system
                        Stainless braid brake lines
                        • 79XS11F
                          • 3563
                          Re: Mount
                          Correct but this fairing came off an XS750 so it may not be big enough or may need some mods.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • wa407mpp
                            • Jul 2007
                            • 717
                            fairing mount.
                            The fairing mount for my bike is two piece the lower half is H shaped with a straight brace that bolts to the down tubes,the top mount is an H with the brace in a U shape and bolts to the stearing head tube by way of a goose neck, the only hose clamps are attaching the goose neck to the U brace. The fairing is clamped between them. I think this is why my fairing has never cracked. I try to make a measured drawing this weekend ,or better yet maybe someone else has one of these mounts laying around and can post some pictures of it along side of a tape measure. I think this mount style would work with Windjammers and other fairing as well and would be a big improvement because it is so solid and was made to bolt on right from the factory.
                            Fastmover
                            lion". SHL
                            78 XS1100e
