aluminum protection
  • 81xsproject
    • 3185
    • Fortuna, CA
    aluminum protection
    I just saw someone talking about this on another forum. If it is as good as the other por-15 products, it is probably awesome.
    Explore POR-15's extensive range of metal protection and restoration products, perfect for bringing new life to any vehicle, heavy-duty machines, or outdoor metal asset with superior corrosion resistance performance and quality. Order online now!
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
  • Bud Manley
    • May 2003
    • 414
    • Clayton, Michigan
    Being the wonderfully helpful person that I am I wanted to try to post the thread where someone had made a bead blast box. Unfortunately the search left me with 5 more pages of tech tips I haven't read yet.
    Theres a ****load of info here!!
    This should work for the theme I was going for however. I need to redo a few Jeep Rims and Jingus of course.
    Thanks for the info.
    79 XS1100F "JINGUS"
    07 V-star 1100
    Do you want it done right or do you want me to do it?
      It does say that it will seal a motorcycle fuel tank without flaking... THAT sounds better than the Kreme treatment anyway. It also has a product just for that, but doesn't write it up as much as this Glisten PC.... maybe they meant sealing the OUTSIDE?
      I get tired of polishing the bits and pieces.. then have them start corroding again after a couple months. I sure hope it works though... all the hours of scrubbing through that old yellow clearcoat that came on these from the factory doesn't bring back particularly good memories. I'd hate to have to do that again with this stuff if it didn't work as promised.
      • 81xsproject
        • 3185
        • Fortuna, CA
        Oh yeah, to follow up his factory clear-coat removal tip. I discovered yesterday that after a few days soak in B-12 chem-dip, the factory clear pealed off like kitchen plastic wrap.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          • 8083
          Glisten PC
          I used that stuff on the fork legs of my XS650 a few years ago. It has held up very well. It's as clear as when it was first applied.
          I put it on with a brush and I would not do that again. It did not flow out smootlhly as advertised. Plan to spray it on for good results.
          I have no idea how to remove this stuff once it's set up. I can't say if aircraft stripper will remove this stuff.
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            When I refurbed my engine cases I used a product called "English custom polish" It is a museum quality polish that did a real good job on my parts. It also claims to contain metal protectors that prevent re-oxidation on maintained parts. they claim that their product does not contain chemicals that promote oxidation. It is also claimes to be PH balanced. It worked very well for me and my cases still look good. I however do not put a ton of miles on my bike.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • Hammerhead1st
              XStremely XSive(Deceased)
              • Jul 2007
              • 330
              • Lawrencvile, GA
              I'd be interested if the stuff really does work. Logged WAYYYYYY many hours just cleaning it up and would like to keep it that way without all the extra work. SWMBO would like that too...
              "Rat Rod"
              79 XS1100 Standard
              87 VMAX cans
              Cheap Japanese Tires
              Cobalt Blue Rattle Can Paint
              Custom Lighting on a Budget
              Perry Center Fire Department
              Perry Emergency Ambulance
              "If we don't do it, who will?"
              Some people have one of those days, I have one of those lives...
              • 79XS11F
                • 3563
                Here's the link .. check out the photo gallery
                Rob
                1978 XS500E
                1981 Suzuki GS1100
