Hey Laxdad
    Hey Laxdad
    Make some room in your inbox. It's still full.
  • midnight1980
    • Mar 2007
    • 312
    • cedar city, utah
    Re: Hey Laxdad
    midnightMAXDAD? i am trying reply too them all, but there not the answers that you want too here..
    i am away from utah at the time in sin city las vegas this weeked away from my midnight at this time and i am having withdraws.
      Laxdad
      I just saw the fairing that you mentioned on ebay. It is just like the one that I have. Mine has a scratch on the winshield that can be polished out. I have all the brackets. Mine has the same Yamaha emblem under the area under the windshield. It is solid, but not a shiney as the one on ebay. Interested? Make me a resonable offer.
      You asked about buffeting, it's not bad at all, but WK and I didn't like the curvature of the windshield, it was kinda distorting.
      Your mailbox is still full.
      • DeanR
        • Jan 2005
        • 1499
        • Finger Lakes NY
        John, not sure what the deal is with the mailbox, it is almost empty now.
        Looks like that windscreen should be below eye level?
        Also, I posted on the final drive mod thread about grease. No responses yet. Exactly how do you get it greased back up properly with the moly. Namely, does any go on the smooth outside of the spline fitting where that goofy zirk fitting leads?
        Thanks!
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
        • DeanR
          • Jan 2005
          • 1499
          • Finger Lakes NY
          looks like my box is still not accepting messages, maybe I didn't delete them correctly?
          80 SG
          81 SH in parts
          99 ST1100
          91 ST1100
            • 7828
            Read TC's help tip with the mail boxes. You may have COPIES of the mail taking up all the room.
              The grease goes inside the cavity where the driveshaft engages the FD. You have to pull the FD off to gain access to this area. Also, when you have the wheel off to lube the drive shaft, put a copious amount of grease on the hub clutch splines as well. The zerk fitting will not adequately lube the D/S splines.
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                Just deleted "sent messages"
                Maybe that was the problem
                FD is off and the inside if the cavity is greased. Just wondering about the smooth outer surface or anywhwere else. Should we just ignore the fitting as it seems to lube nothing?
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                  Don't worry about the smooth surface you've described, or the grease fitting. Don't forget to grease the hb clutch splines where the FD engages the wheel.
