A question about brake lines
  • 81xsproject
    • 3185
    • Fortuna, CA
    I am slowly tinkering away at my hydro clutch conversion. I just need to have some holes drilled and a larger hole drilled or cut 1.83" into my plate for the slave (any one with the right equipment feel free to chime in ). After that, the last thing I have to do is have some kinda line. What I was wondering ,can you do your own metal lines? I was thinking I could run a metal line from near the neck down and around the engine or something. Or does anyone know of any bikes similar in size that had hydro clutches on the right side of the bike that I could use a line from? thanXS
    I have been taking pics of the process and will post a big thread when it is done as I know I am not the only one interested in this mod.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    Jessie,
    I'd be concerned with a solid line going from the FRAME to the engine case, the engine flexes in the frame, concerned about the joint working loose at the engine??
      • 7807
      Jessie,
      If you go to your local V-twin shop, they have the stainless line by the foot, with all the fittings. I would put a single line from the master to the slave, using the banjo fittings. It will probably cost about $75.00, but you will only do it once.
      Ray
      • mro
        • Oct 2005
        • 4276
        • Hayward, California
        Need "flaring" tool (used to make brake lines for cars/trucks) and small tubing cutter. Should be able to get all at a auto parts store. Tools/fittings/tubing should all cost under $50.00.....
        As TC noted, engine/frame flex. Would add a hose connection there.
        One piece SS line as Ray says would be easiest as well as trouble free.
        mro
