New member:TurboXS, super modded
  • AlanB
    • Oct 2006
    • 705
    • Scotland
    #76
    Hi ONR,
    I have been hunting the parts for my 4.00x17 rear wheel for about ten years.... LOL.
    If you can shorten the stem (or get a spacer machined to extend the neck!) then any fork with the same bearing is easy. steering stops are all simple, so not hard to adapt.
    Sometimes it is easier to get some parts you like, and do whatever is needed to adapt 'em than to spend endless hours trying to find the "ideal" combination.
    If you have a good breaker close to you, then go spend a day measuring.
    If not, then get some parts, and start figuring it out!
    If you decide it is going to be a "long job"..... then it will nver get done!
    AlanB
    If it ain't broke, modify it!
    • Yard Dogg
      • Mar 2010
      • 884
      • Tri-Cities, Wa
      #77
      WOW! I've been coming to this forum for 3 years and never knew of this bike. I'm convinced now that no matter what I do, my 1100 will never be as sick as that thing.
      BUMP!!
      • MPittma100
        • Aug 2011
        • 2359
        Super Modded
        I see some signs of pure genius here. Well Done! Well Done! If you haven't already, you need to get some sort of reward/trophy for this one. Enter it in a show somewhere. I feel it is a certain winner.
        PS: Happy New Year!
        MP
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
        • Cuda 69
          • Jan 2012
          • 676
          • Greenwich N.Y.
          #79
          beautiful,alot of $$$$$$,blood sweat& a few tears too,i'm sure went into this beauty.Only way to tell it's a xs,is by the tank and engine.
          FOXS-XS11SG
          1980 XS11SG-sold
          1999 Vulcan classic-sold
          1982 XJ 650-sold
          • TomB
            • Aug 2006
            • 967
            • Cumbria, UK
            #80
            Even the Tank has been modded, its a lot wider than original, though as you say still recognisable as XS11
            I'm sure Math would be interested in offers if you'd like to buy it.
            Tom
            • Mathh
              • Nov 2006
              • 668
              • Beek, Netherlands
              #81
              wow, this thread is alive again ! Thanks for the compliments guys!
              MV Agusta Brutale 910R '06.
              Yamaha MT-09 Tracer '15 grey.
                • 2072
                Originally posted by Mathh
                Hi guys,
                in stead of ruining somebody elses topic I will introduce myself. Have been trying for years to register to this forum but technically something did not work that well. Never got a conformation, but this week miraculously everything went ok. Should have something to do with my new computer.
                Well, my name is Math Huskens from the Netherlands. 50 years old, riding XS1100's from when I was 22 years old.
                Former president of the former Dutch XS1100 club which died soon after me and my friends left the board for the younger generation a couple of years ago. My friend Ferry Labbé is now rebuilding the Dutch site having this and the UK site as an example (xs1100.com). There will be no club anymore as we no longer have the time to support it.
                Owner of the XS1100 Turbo (purchased new in 1982) which I have seen passing by in several of your topics over the past years.
                I'll put down some pics for details, but the bike has been altered slightly afterwards before travelling to the UK meeting (Öhlins monoschock and some small things.
                Okay then, here it comes fromt front to rear:
                FZR1000 USD front fork with KAD monoblock sixpacks, YZF750 discs, 140 front tire, Phoenix wheel 3,5x17 , RGV250 front mudguard widened, YZF750 handlebars with milled oil reservoirs.
                Honda SP-1 clocks, RB fuel ratio gauge, gastank widened to accept 36 liters in stead of 24, double pingel fuelcocks, return line for DFI.
                Engine now stock except for 6:1 in stead of 9.2:1 comp. Aerocharger (max 15 psi, integrated waste gate, variable vanes, own oil reservoir) fitted with handmade manifold and doublesided intercooler. New oil filter base plate with integrated thermostat and outlets for cooler and for car type filter. Intake side has an altered Kawasaki 750 turbo DFI set-up with 1100 injectors, welded-shut airbox. Mounted on airbox are two waste gate/ intake membrane combinations from a Yamaha 650 turbo. Engine management (fuel and ign) is TEC from Electromotiv and is PC programmable. Power output was 220 (european) hp, torque 303 Nm / 1900 rpm (I have no clue what that is in US numbers.....) last time it was on the dyno. The alternator has been replaced by a FZR1000 one with a belt drive. Clutch actuation is hydraulic.
                Footrests and controls are handmade in combination with some Kawasaki and Ducati parts.
                Exhaust is titanium from Bos, sound is social. Not loud at all.
                Seat is mono from a YZF750SP and covers the Bosch fuel pump and filter, the R1 battery and the Electromotiv. Swingarm and shaft(drive) are from a Yamaha FJR1300 fitted with a CBR900 top brace but now at the bottam and a GSXR1100 shock mount welded to it. Shock on the pics is from a 1999 R1, now replaced with an Öhlins for the same. Rear wheel is also a Phoenix wheel 6x19, originally for a GSXR1100 but with the cushdrive modified to accept the Yamaha drive, and fitted with a 210x17 rear tire, rear brake is GSXR1100, caliper is from an R1 modified to fit.
                Well, that was a mouth full. I also have a couple of other bikes but i will not bother you with that apart from the fact that one of them is a black 1980 2H9 with 17000km which I recently bought in Austria to make it as new (still looking for a set of original exhausts, anyone? )
                My girlfriend rides the black special with the 3 -spokers.
                Have fun!
                Hi TC, I've been pondering an alt. mod like yours, for my '80G fulldresser, only with the parts Math has used.
                I too would like to wear heated gear x 2 for my Better Half also, plus some LED spot/driving lights on the crash bars to illuminate the turns as the Pacifico is a fixed light.
