All the time I've had this XS11 the handlebars were always just a little out of alignment. I tried more than once to correct the problem by loosening the tripple tree bolts on the tubes and the wheel bolt and tried to turn the handlebars to a straight position while holding the front wheel. Just couldn't get it just right. Today I decided to take it apart and see why. Well, the why is the left tube is bent just a little, right where it enters the bottom of the tripple tree. GGrrrrrrrrr I wonder if anyone has a good one that won't cost an arm and a leg. I figured I might as well do it right and rebuild the tubes if needed and refill with oil.
Front end alignment...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesTags: None -
With it being slightly bent you could take the upper fork tube to a shop that has a hydraulic press and straighten out your tube. At the shop I work with part time we do this all the time. We use wooden blocks to hold the tube on both ends and then press where the bend is alittle at a time until the tube is straight. Just a thought.Do'Lee
XS1100SF "Green Hornet"
(1) XS1100LG "Midnight Dream" Restoration has begun.
(2) XS1100LG "Midnight Madness" Waiting to be next
(5) multi partsters for bobber "Ruby Red II" On the list.
SR500H "Silver Streak" -
I have just what you need. Stock set of standard forks from a 78e xs1100 had approx 24,000 miles on it. Both forks price includes shipping. the forks may need new seals but not pitted and straight. $60.00 andreasComment
