Ok, so I'm on the way home from work and the "headlight"
light comes on.
Great. I just got this thing running, now the gremlins start showing up.
Light was getting high and low beam just fine, no problems. Now, no high or low! Headlights don't just burn both sides out, eveyone knows that.
Hell, I know what to do, I read XS11.com. I am informed!
Must be the crappy fuse block, or the headlight relay, or the RLU.
I attack immediately, armed with my VOM and jumper wires.
Side covers:OFF
Fuses: CHECK! dammit.
Take off seat.
Take off tank.
Look at all that stuff, must be a problem in here all right.
Relay OUT!
Hot wire it, hey,it clicks!Hmmm
Hot wire it and check the switched side, that works too. Ohfur two. Not lookin good for the home team.
Jump the relay plug, "Headlight" light comes on.
Stupid "headlight" light. What's with that thing? I mean, really!
Look at the RLU, don't want nuthin to do with that. Didn't read that far.
Pop the headlight out. Check the light with it still connected(duH) it checks good.
Must be the Vetter wiring.
Take the pocket apart. Wrong one.
Take other pocket apart. Check plugs, check ground.
Now I got stuff scattered all over the place. Lookin like Sanford & Son.
Check continuity. Check voltage to plug. It's all good.
WTF? Plug it in, "headlight" light come on.
Unplug the Vetter, check the plug on the headlight side. Checks...... no good. SMACK head!
UNPLUG the light and check it. Whaddya know, its burned out. Both sides. Maybe next time the "headlight" light comes on, I'll swing into the Zone and grab a bulb.
Oh well, I learned all about the wiring system today.
That's why my picture says "GENIUS".
light comes on.
Side covers:OFF
Take off seat.
Take off tank.
Relay OUT!
