R-12 replacement options
  • excess11
    • Oct 2004
    • 256
    • Rockville Md.
    What r-12 freon replacements has anyone tried? I am not really looking to go the r-134a route. I would like to find a drop in replacement. I have heard that, Freeze-12 and Enviro-safe refrigerants work good for r-12 replacement. Any expierence with these or any other replacements that work good !!
    Dan ( A.K.A.- MacGyver )
  • Targetman
    • Feb 2003
    • 130
    • Oshawa Ontario Canada
    I tried a product called Duracool.
    Duracool website
    Kit came with two small cans of their hydrocarbon refrigerant and a small hose with adapters for r12 or 134a systems.
    It did make my system work again, when I bought the car the system was so emty that the compressor would not even come on. It is not as cold as it should be, but I didn't know how much to put in, so I am going to try again. Bought the re-fill kit at a Napa store here in Canada. I don't know if they carry it in the U.S. but the Duracool website says U.S. residents can buy directly from them.
    My car was R12 by the way.
    1979 xs1100sf
    1972 cb500 four
    • LoserShoes
      • Apr 2005
      • 524
      • Bangor Maine
      A change to R134a is not really that big a deal, you can buy the kits for not a lot.
      And regardless of what you change to, you really got to pull a vacuum on the system to dry it out.
      Steve
      73 Yamaha DT3 - DirtyHairy
      CZ 400 MX'er
      68 Ducati Scrambler
      RC Planes and Helis
      • excess11
        • Oct 2004
        • 256
        • Rockville Md.
        a/c
        I have a vacuum pump that can draw 28 inches of vacuum so that is not a problem. It was a lucky yard sale find for $10.00. Works perfect! I hear that to do a propper 134A changeover. You must dismantle the entire system flush out all of the exsisting oil replace all o rings. Then put in synthetic oil and 134A charge. I was told the disadvantage of 134a change over is the chemical make up of 134A is much smaller than that of r-12 so a tiny leak with r-12 is a gusher with 134A. Is this correct?
        • eroellig
          • 229
          • Arkansas
          Re: a/c
          I believe that R134A does have a smaller molecule size, so it will leak easier.
          The biggest thing that I know of to having your converted system perform like the original is that R134A systems need a condenser (the part in front of the radiator) to have about twice the surface area as is required for R12.
          Eric
          Eric Roellig
          1980 SG w Windjammer V & KG hard bags
          **Very first bike**
          Current condition: Running!!! Lead, follow or get the #^%# out of my way!!!!!!
          • webbcraft2150
            • Sep 2002
            • 1605
            • AUSTIN.TX
            Try this site for full info. www.ackits.com
            • ccogswel
              • Jun 2005
              • 302
              • Bowling Green, Ky
              I was told by an old a/c man, that r12 needed to have vacuum pulled on the system as there can't be air mixed into the system with it. But as the r134 you didn't have to worry about pulling vacuum. If you use a replacement alternative to r12 you may ask if you have to worry about any air you let in when you hook up to refill. There is a way to purge the line as you hook it up. Just make sure you hook up to the low pressure side I think, if I remember correctly. It's been almost two years ago when I done it myself.
              If I was you I would just convert to r134. Just replace the o-rings with new ones. Flush the system and replace the dryer. Pull vacuum to about 23lbs or what ever you can get and let it sit for a hour with the gauge hooked up to see if you have any leaks. If your lucky fill up and be cool
              Chris
              79 XS1100 Standard aka: Mutt
              Gimme Fuel Gimme Fire!
              • LoserShoes
                • Apr 2005
                • 524
                • Bangor Maine
                It's not so much having air in the system, it's the moisture. Haveing chunks if ice in the evaporator aint gonna make it work to good.
                Steve
                CZ 400 MX'er
                68 Ducati Scrambler
                RC Planes and Helis
                • HobbyMan
                  MeatHead Idiot "GURU"
                  • 1801
                  • Colleyville, TX
                  I believe that R-134A has a less heat capacity than R-12. So you need more of it to do the same job. AKA: larger compressor, etc.. On small cars you don't notice it. If you live in the South, some places in Mexico, right across the border, sell R-12 real cheap if you just need to charge your system. I wouldn't switch unless I had to. "If it ain't Broke don't fix it"
                  Acta Non Verba
