not baffled
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    not baffled
    I have a Mac (I think) 4 into one header I won off Ebay. As someone else noted, there is no baffle in the muffler.
    Anyone have an unused baffle they'd be willing to part with?
    My plan for this is to fabricate a 'Y' where the muffler section attaches to the header collector and run 2 SuperTrapp mufflers. Using the discs I should be able to dial in the backpressure to stock and have a very quiet bike.
    Right now the exhaust is drying with it's 1st coat of paint before baking in the oven to cure it. Wife and kids are gone for a week so I can do these things.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
  • dwales
    • 119
    • Karthaus, Pa.
    If you are going to use the plates on the Supertrapp mufflers to dial in the back presure, what do you need baffels for?
    Highlander
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      The baffle is for the interm before/while the 'Y' is being made (and I save-up the $300 for 2 new SuperTrapps)
      Pat Kelly
      • Parr8hed
        • Aug 2003
        • 444
        • Southern Indiana
        good plan, I run a single supertrapp and love it. I do not use any of the discs on the back and love the throaty wide open sound. Not sure about the neighbors though?
        Travis Miller
        1978 E
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          If you want that pipe to actually improve performance you best pull that steel baffle out of there and drill all the holes at least 50% bigger. Unless yours is different then mine you can't put baffle material in that pipe or the air flow will be grossly deduced. I have my steel baffle drilled out and the stop plate is removed.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
