So, normally I would not ask suck a rediculous question, but since I just had to ride home with no clutch my less than a year old cable broke. Does anyone have an opinion between Yamaha, Barrett, or Motion Pro?
Need opinion on cables
'81 XS1100 SH
Sep. 12th 2015
RIPTags: None -
This stupid one I just broke, broke right at the lever-bead, and I lubed it before I put it on (5-7 months ago and garage kept). Just a shoddy cable, I think.'81 XS1100 SH
Sep. 12th 2015
RIPComment
Well, I ordered a barnett, because, suprise suprise, Yamaha didn't have one in stock.'81 XS1100 SH
Sep. 12th 2015
RIPComment
And not only keep the cable lubed, make sure the barrel end is lubed too, friction there will bust that sucker right off. Mikes XS has a nice little cable lube tool with which you can just blast the housing full of chain lube.Shiny side up,
650 Mike
XS1100SF "Rusty", runs great, 96k miles
XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]Comment
The old gray biker ain't what he used to be.Comment
Right Tony, like the clutch lever on my 400. Not to worry, Mikes XS has new levers cheap.Shiny side up,
650 Mike
All my stuff is in good shape. Upon removal, it looks like the metal bead just split and the cable came right out.
I got one of those lubers at the HD dealer cuz both the metrics were out of stock and I needed one. It seams a little lareger though. Do HD's have larger cables?'81 XS1100 SH
Sep. 12th 2015
RIPComment
I lube cables with a plastic baggie with oil and let the cable hang for a few minutes. I almost never use my pressure cable luber because it only uses the canned stuff.
Some Harleys do have masive clutch and brake cables
Plastic baggy works ok but I've also got one of those old pump type oil cans and it works fine with my pressure luber.Shiny side up,
650 Mike
